Headlight issues
Old Aug 17, 2005 | 09:27 PM
bootleg_'s Avatar
3rd Gear
Headlight issues
Hey,
Maybe someone can tell me if the problem is the ballast or not. When I turn on my headlights I'd say about 75% of the time, the right one doesnt ignite. The left one works 100% of the time. If I turn the light off and on a few times I can get the right one to come on, but thats not very often. Does this sound like the ballast? Let me know. Thanks.
Old Aug 17, 2005 | 11:13 PM
Speed42005's Avatar
Originally Posted by bootleg_
Hey,
Not blast..more sound like circuit cold solder.. driver for light may be have bad connection or lose contact on board
Old Aug 18, 2005 | 08:20 AM
Dare_IL's Avatar
Need a WHAmbulance
It sounds like the igniter is going out.
You could check it out by switching the igniter from the left headlight.
One more thing to check. Make sure there isn't any water sitting in the ballast. Could be enough in there to short out the ballast.
New ballast will cost ~190, new igniter ~165, with OEM Parts.
From a dealer ~460 for both.
Old Aug 18, 2005 | 11:28 AM
burn-one's Avatar
You mean a cold solder joint??
I would lean towards the igniter too.
Old Aug 18, 2005 | 12:06 PM
obespalov's Avatar
I had the ballast go out as well, but spend unnecessary money buying both Ballast and igniter to realize it was not ignitor, but Ballast. Switch ignitor on each side to see if it's that first. Btw, if it is the ignitor (which I doubt) I can sell you mine, which, as mentioned above works perfect, as my problem was the ballast. Do a search and you will find instructions on removal...Ballast was a little painfull b/c bumper needs to be taken off but is managable with instructions. whatever you do, Just don't get Acura to do it.
Old Aug 18, 2005 | 12:13 PM
obespalov's Avatar
oh, and btw, if you do take it to stealership to just get checked out..remember this, they actually told me "Ballast and ignitor have to both be replaced", when only Ballast needed replacement.
And Finally, attempt to find the ballast at a Junkyard. If that fails, http://www.acuraoemparts.com/delray/jsp/srchrslts1.jsp
I believe the part is called "inverter".
Old Aug 18, 2005 | 03:34 PM
Tom Blasing's Avatar
is the Mighty Favog
Hey,
Sounds like it to me. Go ahead and get it replaced, turning the switch on and off a lot like that is putting a strain on the ballast that does work.
Old Aug 18, 2005 | 04:38 PM
your ballast is gone, get a new one.
Old Aug 19, 2005 | 03:41 PM
bootleg_'s Avatar
3rd Gear
Thanks for all the input guys. This board rules.
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
acuraST
Sep 17, 2015 02:31 AM
JnC
Sep 11, 2015 06:06 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
