Headlight has purple tint
So after researching on here I find out that my headlight is probably about to go. The driver's side HID is giving off a purple tint. If I keep the lights off for a while and then turn them on they are both "white" but the driver's side slowly fades to purple.
Is it the bulb or the ballast? And where is the best place to buy the replacement setup, HIDExtra.com?
The D2R right?
http://www.hidextra.com/HID+Bulbs/D2...28PAIR%29.html
'13 Hyundai Sonata
I know DDM Tuning sells their bulbs for $15. A couple people on here have run them in the OEM stock with success.
http://www.ddmtuning.com/Products/HI...lacements-Pair
6000 loses a lot of white light in front of the car
5000 is a good compromise
4300 was stock and gives the most actual light on the road surface
higher colors pick up the reflecto paint in road line markings
The 5000k Philips ones on eBay are running for $130 a set
http://cgi.ebay.com/ebaymotors/NEW-O...Q5fAccessories
And the 4300K Philips ones are running for $35 each
http://cgi.ebay.com/ebaymotors/PHILI...Q5fAccessories
You'll be fine...5K is plenty light output and a little bluer/less OEM. Which is what I dig.
Personally, I would have gone for the DDM, raptor kit, 30 bucks with lifetime warranty and I would have just kept the ballast/ignitors as extras for the future.
But supporting site vendors is great too!
there is no problem with running aftermarket anything...you plug it in, it turns on, it has the same or similar draw and you're good. I helped a friend use DDM for his low beams on his 03 TL...it came out perfect, no leaks...no condensation and best of all, cost him 30 instead of 300.
