Headlight clearing question
my buddy cleared his headlights on his audi and instead of baking the light and having to reseal it he took a flat head screw driver and broke the refelecter into pieces then they just fell out one of the light bulb holes, anyone try this before?
I have done it on B6 A4's a lot. We used a tiny drill bit then sealed it with silicone. I havent looked at our cars headlight to see if it would work but I will later when it comes back from the transmission shop and let you know.
aight cool. iono i think if its done right and not just chopped at and broke it will work. im just iffy about re sealing my headlight i really dont want to deal with moisture problems
Resealing has never been a problem with all the headlights I have done. Just using a dremel to exactly drill out the little tab was annoying and took a lot of time.
that could actually work but you'd have to break the whole reflector into tiny pieces because i dont remember the hole being that big.. i wouldn't try it, baking the headlights isn't as hard as you think
did it to mine and no leaks for about 5 months now.
abptltypes02, I got an extra pair of casings if you want. The drivers-side is cleared+no fogging/moisture issues. The passenger-side's chrome trim (..on the inside of the casing) is trashed.. and you'll need another one. Its already cleared, so all you need is the new chrome piece. Lemme know if your interested in buying them..
ive done it, it works fine. Just dont scratch the lense. I prefer the baking method tho.
I recommend that you try it.... it will be fun
well now im gunna wait cuz ill tl has a extra set and hes going to try something new and instead of blacking out the inside hes going to color match it. so if all go's well on his end ill buy his blacked out/ cleared lights and just call it a day
tman570
06-11-2019 07:56 AM
