headlight bulb blow up
Old Jul 18, 2010 | 11:06 PM
nathanli's Avatar
Hi Guys,
I passanger side HID bulb blow up (2001 TL). I pulled out today and found out the glass tube only has a small piece left at the base and another small piece hang by the electrode. How do I remove the middle piece from the housing? if I replace another bulb in w/o remove the broken glass tube, will I have any problem?
BTW, do I need to watch out for the direction/orientation of the electrode when I replace a new one? I did not pay attention to the orientation when I pulled it out today.
Thanks a bunch.
Old Jul 19, 2010 | 11:30 AM
01tl4tl's Avatar
yes the electrode MUST go in the same way=critical to light output=remove the other one to ck or maybe see thru headlight lens cover
all broken material must be removed
NOTE DISCONNECT BATTERY NEG cable and dont work on lights within a few hours of them being used
system holds high voltage that can kill the unsuspecting
time allows it to bleed off the stored power
IS there mositure behind the housing lens?- very common and will blow bulb AND kills ballast
Any symptoms before failed--purple or pink a minute at startup or flikker or on and off?
That will help diagnose if the prob goes further than just old bulb
most 99-03 are ready for bulbs--they last about 2500 hours for stockers and lose color and brightness with last of life
Old Jul 19, 2010 | 11:33 AM
01tl4tl's Avatar
reminder to all- never touch the bulbs with bare hands- wear latex/vinyl gloves
If you accidentally tough the glass, wipe it off with rubbing alchohol on paper towel
There is oil in your fingers that cause hot spot when baked onto the glass, and reduces its life by a large number of hours
Old Jul 19, 2010 | 12:26 PM
nathanli's Avatar
I did not see any moisture in the housing and did not notice any problems before it's dead. When you said to check the electrode orientation in the other headlight; do I need to match it or mirror image it?
Old Jul 19, 2010 | 08:05 PM
01tl4tl's Avatar
match them!!
anyone recall if the electrode goes on the top or bottem?
Old Jul 19, 2010 | 10:29 PM
nathanli's Avatar
Thanks a lot, 01tl4tl
Old Jul 20, 2010 | 12:05 AM
01tl4tl's Avatar
be careful and good luck - let us know how it goes
remember those gloves!
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
hashbrown
Sep 29, 2015 12:13 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
h22lude
Sep 27, 2015 06:22 PM
