Headlamps
Headlamps
I Replaced my Highbeams on the TL (which was a big bizoch to do). THe bulb where just Eurolite xenon 9005 65 watts same as factory spec. OK now my problem is for my sisters RSX i got some Supere Plazma xenon, hid wanna be's. They are 80 watts but the factorys are only 55 watts. Can this do any effect to the wiring.
I've heard instances where the housing reflector/plastic "dulls" up because of the extra heat from 80W bulbs as well as the harness melted and shorted out. I would NOT go higher than stock rating for Halogen bulbs.
Originally posted by aMiR
read on the box and see if they really run at 80 watts or if they are 55watts that look like 80 watts cuz most of those fake bulbs say that they just look that bright
It's the brightness that make them look like they are 80 watts bulbs. If they use some special gas in the tube, they COULD simulate the color of HID, but not brightness. However, the power consumption is still the same.
Tatewaki
Tatewaki
i used 100 watt bulbs in my legend in both high n low beams but the stock wire's are not rated for that wattage nor is the socket...but they do sell a heavyduty wire harness kit for the highwattage bulbs...... http://jen.liu.tripod.com/suvlights/id14.html
Originally posted by dnd2984
Can u explain how the bulbs will get 80 watts if the facotrys only get 55watts
Think of the 55watt bulb as a small engine and a 80 watt bulb as a big engine .
Comptech Freak
i don't know how the circuit thing works but i know it will be overheated for sure and it won't last more than a yr....
i heard these fake bulbs has a small amount of xenon gas to mix with the halogen bulbs
i think you know the answer to your question....but if u wanna use em you can do what i said in the above post with the heavy duty harness.....80w bulbs are nothing...they have 140w bulbs now :wow:
Becareful about using "japanese brand fake HID lights", they may or may not burn out your housing. I've had it happen so many times to my Maxima that I finally got pissed and switched back to stock. Out of all my friends, only one of them didn't burn their housing using these bulbs. If you want fake HIDs, get the PIAA brand. They are more expensive, but atleast you don't have to keep buying new housing.
tman570
06-11-2019 07:56 AM
09-17-2015 09:01 PM
