Head light bulb replacement
I have 2002 Acura TL type S. My driver side head light bulb has gone bad.
Got a new one and install it, did not work, checked the fuses and relays ... thay look fine.
Any suggestions what could be the problem?
Did you try the left right swap and see if its a bulb or other problem
Did the bulb go pink before quitting? Tahts the normal wear out sign
The remaining parts are the ballast and capacitor- their failure will make sudden stop of light
check the Off Topic private sales for one
or the local auto recycler yard should be able to hook you up
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
wusty23jd
09-24-2015 11:41 AM
