Harsh shifting?
Old Jan 30, 2003 | 06:10 PM
spyder5786's Avatar
Harsh shifting?
Hey guys..i have a 99 TL and lately i've noticed its shifting kinda harsh between 1st and 2nd gear. All the other gears are perfectly fine, they shift nicely and smoothly. Has anyone noticed this on their car? And you guys think it will be a major problem?
Old Jan 30, 2003 | 06:32 PM
badazzTL's Avatar
Peach Tea
Re: Harsh shifting?
Mine has been doing that for months. I hope it blows
Old Jan 30, 2003 | 09:05 PM
lhommec13's Avatar
Why on earth would you want your tranny to blow up? If you also have a '99, you're not covered under Acura's extended warranty!
Old Jan 30, 2003 | 11:29 PM
badazzTL's Avatar
Peach Tea
i have a 2000, so im covered. I want it to blow so i can get a new one and hopefully the new one doesnt shift hard...
Old Jan 31, 2003 | 01:08 AM
Darkshear's Avatar
l33t
I have a '99 and its gettin rough. I tottaly want mine to explode because my factory warranty is toast march 30th... it was one of the last '99s...
Old Jan 31, 2003 | 01:15 AM
Allout's Avatar
Blown is Best
How many miles do you guys have on your 99's?
Mine was shifting a bit rough around 35K. When I added a tranny cooler and flushed the system, my shifts smoothed out and it's been fine since.
Old Jan 31, 2003 | 10:33 AM
kwieching's Avatar
I have 120,000 km's on mine and I had it flushed recently and now it shifts smoothly.
Old Jan 31, 2003 | 11:11 AM
steadydaddy's Avatar
Tell me more about flushing. I've been contemplating on having that done and hope it improves shifting. What do you need terms of parts (filter, gasket, ATF brand/grade)? Is there a flush kit available? Does this require dealer service?
Though I bought my '99TL used (38K) 3mos ago, I've noticed shifting from 1st-2nd a bit hard sometimes compared to other cars that I've driven (I30, ES300). I brought it to the attention of the dealer and the serviceperson said "...that's quite normal. The computer on these cars depend on sensors that dictate the right gear." Nevertheless, I'm hoping that a regimen of flushing would prevent an untimely demise of the tranny.
Old Jan 31, 2003 | 11:27 AM
kwieching's Avatar
I didn't have time to do it properly so what the mechanic did was just drain and refilled it. I think the proper way is to drain, drive a bit and further drain more...fill up again, drive, drain and then refill till the color comes out Red. Does this sound correct. Plus you have to get the fluid from Acura because apparently you're not supposed to use Dexron III as a long term tranny fluid.
Hope this is accurate and helps you.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SidhuSaaB
May 30, 2020 12:40 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Froid
Sep 27, 2015 06:16 PM
