hard time getting front engine mount out
im having problems getting the mount bracket off the top of the mount...its just not clearing the hole on the top of the mount. i am jacking up the engine, but it still isn't clearing, and all it's doing as i continue to jack it up, is lift up the entire car. any ideas?
well... couldn't remove the one bolt on the mount because i didn't have the universal joint. so i'll try it once more tomorrow. is there any easier way to remove the bolt on the mount bracket that's on the engine? it's so hard to reach.
Need an OEM lip kit on my
Also...we didn't have to loosen the side motor mount at all.
Hopefully you did not damage something.
For details you can search my posts, but keep in mind that you MUST remove all 3 mount bracket bolts as well. You MUST remove mount and the bracket together.
That is the proper procedure. I doubt that the mount even can be removed (without damaging something) without removing the bracket.
Also remove exhaust heat shield (three small bolts only) and use long extension so that you can reach from above that fourth mount bolt seemingly impossible to reach from above.
When assembling, do put the mount and the bracket together in place first and only then start putting bolts.
Oakes
Wash & Wax
10-12-2015 11:17 AM
