Hard Steering???
Hard Steering???
Don't know if this is normal ,but i've been having a steering issue. For some reason it takes a lot of force to turn the steering wheel. My friend also has a tl, and his steering is light and smooth. Is it because my power steering fluid is low??? Compared both our fluid levels and they both seemed to match up.
the fluid level should be about halfway between the lines on the PS res
If the fluid is old- more than 60k miles- its ready for a flush
See DIY section its pretty easy to do
Check tire pressures
Check steering parts under the car for any broken boots or damage to parts
I've had the same problem for a long time, I checked PSI/Power Steering fluid and everything. Then I got mad so someone took a look at it turn out that the ball joint wasn't getting greased properly, they said it would need to be fixed soon but I didn't know how soon. So about a month after I was turning into my friends street and the joint ripped out of the socket because it was dry. I had the entire thing replaced for $400.00 now it drives very nice. Sort of pulls but I'll get balance/wheel alignment soon.
mlody
12-04-2019 02:11 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
