Is it hard to change front tranny mount?
Lots of threads on it
1.5 hours a few wrenches a socket set and a floor jack with small piece of wood to protect the parts you support with it
Does it look squishy collapsed or was a strage fluid unlike any normal oil, that has appeared under the center front of the car when parked? That would be front mount leaking
The Acura parts counter guy can look at the car and say yep here ya go
120 bucks have a nice day- they replace them with transmission all the time
well it's not that front engine mount. it's the mount next to the driver side wheel. and no, there is no oil because i dont think that mount is filled with oil. it's just the rubber urethane for that one if i'm correct. thanks
ok the one on the passenger side then correct
The same one you have to deal with when replacing timing belt
approx 1 hour
wrenches sockets floor jack
If you know how to do brakes- you can do motor mount
All you do is support the engine underneath so it doesnt fall
approx 1 hour
Tranny mount. easy. Place jack under trans to support. Un do the bolts, Raise trans via jack to lift out and replace. Also id replace BOTH mounts if your doing so. There are 2 there right next to each other
sputik
Sep 7, 2015 01:40 PM
