H&R Springs..
H&R Springs..
What's the difference between Sport springs and OE springs? I'm about to drop my car, and I don't want it too low. I want like a 2 finger gap. What should I go with?
Well I mean it in two ways.........
You'll get less of a bouncy feel with shocks as well. You won't blow your shocks out...and the ride will be more sporty.
Also to install the springs is not an easy job...unless your doing it yourself prepare to spend at least 200 - 300. It'll cost the same to install the springs and shocks.
i have the sport springs. they're a little lower than the oe ones. i think it's 1.75 in the front and 1.5 in the back. pretty even look overall, no rake. i personally like it better than the oe but that's just my opinion.
the ride is a little stiffer, but in NY everything is stiffer. like someone said earlier, you'll prolly have to get new shocks as well. good luck!
dude!..
get the shocks..
especially the front!..
i did the springs..and i should have done the shocks.
my front shocks went really fast, after the comptech install...
and it is basically the same instalation...
you're right there!..
get the shocks..
Shock choices are
Tokico Blue ~=$300
Tokico Illumina ~=$500
Koni Yellow ~=$600
The last two are adjustable.
P.S. I concur with getting shocks at the same time. I had CT springs on stock shocks and they started a bit bouncy and have progressively gotten more annoying. It's getting to the point where stock springs and shocks were more comfortable which was not my goal. Getting Illumina's put on within the month.
Tokico Blue ~=$300
Koni Yellow ~=$600
Leo Type-S
06-07-2006 01:12 PM
