H&R Race Springs Bumpstops ??
im installing the h&r race springs in my 2003 acura tl type s tommorrow ( part # 51858-88) and i wanted to know if i should cut any of the bumpstops....any advice will be appreciated ..thanks.....
if u don't cut there will be very minimal shock travel...i even had to cut mine when installing the H&R sports...i accidently cut it again when i installed my Gcs:p
I got H&R race springs, and I recommend that you get spring isolators (they are an abestos type looking material that goes over each coil of your spring). If you don't have them, you will hear a squeak coming out everytime you hit a bump. Quite annoying. After you put these spring isolators on, the squeaks will go away (unless you hit a bump real hard, then you might hear one). Good luck!
Where did you get spring isolators and where do they go? Between the spring and the car frame? Can you install it without taking ur suspension out? I get squeaks when i turn the steering wheel, but i don't kown what it is.
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
