H.i.d
2003 TL-p
![](http://www.hunza.co.nz/images/productImages/architectural/KelvinScale.jpg)
anything higher than 5k has less light output and cuts down on usable light output resulting in less visibility . 6k will not be bright enough and the only reason you would want 6k or higher is to have a blue tint to it.
stick with 5k if you want to see the road, but its your call.
id recommend 3000k for fogs....idea of fogs is to work in an already high glare situation (fog) so 3000k provides the most lumen output with the least glare
4300K bulbs are the best if you want maximum visibility. Higher Kevin ratings trade performance for color.
http://intellexual.net/hid.html
Glepage22
25
09-12-2014 12:14 PM
