Guides on replacing interior lights
Old Aug 4, 2009 | 07:30 PM
It's Clutch's Avatar
Hello Officer
Hello, I currently dont have my books that came with my car. I did look around but no results, are there any guides on how to:
-Swap out:
License Plate Lights
Dome Light
Door Courtesy Light
Map Lights
Sorry for the noobish question, opening up stuff just isnt my thing.
Old Aug 4, 2009 | 08:28 PM
SLushhYYY's Avatar
Keep It Simple in
Take a flathead, but it in the little slit on the cover and pry it off.
Liscence plate- Either screw off a little rubber thing on the top of your license plate and swap bulbs. Or if it doesnt have the little cover over it, just swap bulbs.
Old Aug 4, 2009 | 08:38 PM
hANDYcaptd's Avatar
It's the Halladay season!
Yea, super easy. Just pry off the cover, and replace the bulbs
Old Aug 4, 2009 | 08:39 PM
Hello Officer
even for the map and dome, just pry off the grey cover?
Old Aug 4, 2009 | 08:40 PM
SLushhYYY's Avatar
Keep It Simple in
yessir
Old Aug 4, 2009 | 08:56 PM
fobstylez's Avatar
if you look carefully, there should be flat head slots, wedge one in there and pop that sucker off.
Old Aug 4, 2009 | 09:42 PM
hANDYcaptd's Avatar
Grey? Mine are clear
Old Aug 4, 2009 | 10:39 PM
Hello Officer
i was talking bout the grey outline around the clear part. Cant wait to do the LED conversion, just gotta get these HID's installed on my pilot.
Any help on leveling HID's to make them so they dont blind others while driving at night. They are phillips HID's 4300K
Old Aug 4, 2009 | 11:44 PM
SLushhYYY's Avatar
Keep It Simple in
no man...you take off the clear part
Old Aug 5, 2009 | 12:01 AM
Hello Officer
gotcha
Old Aug 5, 2009 | 12:08 AM
VoLLy's Avatar
Meridian
everything is just pry off with a flathead screwdriver but use a screwdriver to take off the license plate bulb holder and pull it through, everything should be common sense when taking the bulb holder apart.
Old Aug 5, 2009 | 04:34 PM
'02_TL-S's Avatar
Traded in my
I used an old giftcard..shove it in the crack and pryed..that way I didn't risk accidentally slipping and scratching the cover or something else. And the card exerted pressure on more of the cover than a screwdriver will..that way you don't risk a crack too. Done that before on older cars..
Old Aug 5, 2009 | 05:12 PM
fsttyms1's Avatar
Take a small flat head and wrap the end with a piece of tape.
Old Aug 5, 2009 | 09:33 PM
totaledTL's Avatar
Pick up a set of nylon pry tools at Harbor Freight. Cheap & very useful for things like this. Screwdrivers are more likely to mar or crack lens, upholstery trim, etc.
http://www.harborfreight.com/cpi/cta...emnumber=95214
Gift card idea is good, hadn't thought of that.
Old Aug 6, 2009 | 02:25 PM
9932's Avatar
2G wanting 3G
hammer...
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
bailey24
Nov 21, 2015 08:43 PM
handsom-hustla
Nov 13, 2015 05:04 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
