Ground control
Old Aug 13, 2001 | 02:30 PM
Sniper_mjh's Avatar
Ground control
I want to lower my car, and i have read most of your posts on this. Are ground control's good. I know i like the locking mechanism on them, the one alen wrech is much better than needing those 2 tools that other places sell... So basically, if i want to be able to lower whatever ammount I want, are those the way to go???
Old Aug 13, 2001 | 02:59 PM
Cuong's Avatar
They are one of the better affordable sleeve/spring type coilover systems. This is basically the way to go for lowering adjustments that is relatively inexpensive. Your next option is a true coilover setup, but be prepared to spend at least $800 for adjustable height and if you want adjustable height and dampening, you're looking at around $1200 for starters.
Old Aug 13, 2001 | 08:58 PM
NSX4dr's Avatar
Original Member #81
I love my Ground Controls........
Old Aug 13, 2001 | 10:22 PM
[VTEC]TL's Avatar
RWD convert
So do I............
Old Aug 14, 2001 | 11:12 AM
ChinozTL's Avatar
I was reading up on Ground Control's website and it said somewhere that to properly adjust the coilovers you need a scale under each wheel to make sure its even or else it will mess up da whole ride. So i was just wonderin how do you know if you set all the sleeves at the exact same hieght. Is there like a measuring bar on the side of the sleeve of suttin like that??
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
