ground contrl coilovers?
I am currently running Ground Controls with Tokico non adjustable and I dont really like the setup. I mean it is decent but if you are willing to fork out about 600-700 for this then might as well put out a little more and get the apexi's. I have sat in a car with that setup and the ride seems nicer with it and it is a coilover and shock setup that is made to work specifically with each other.
so for the apexs, you can use the stock shocks? and there will not be anything bad happening to the stock shocks? also, is your ride (chinoz tl) with the tockicos and GCs better than the ride would b running handr sport springs and stock shocks? and when u say you dont really like it...doyou hate it...or s it ok..?
Eibach makes the springs for Ground Control, so you know it is good quality. As for how long it takes to set them up, you will get different answers. It's a quick twist of the wrench (~5 minutes total), but most say you need to almost get a professional to do it, so each side is setup EXACTLY the same way, for safety.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
4drviper
Sep 23, 2015 07:42 PM
