Greenstuff Rotors
Old Nov 24, 2004 | 06:05 PM
memphis2883's Avatar
Greenstuff Rotors
Will you actually be able to see the green part of the rotors...cause that is something that i actually do not want to see....also what should i use to change the color of my calipers.............
Old Nov 24, 2004 | 06:52 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
greenstuff rotors?
EBC makes brake PADS called Green(stuff) but no rotors... and yes you can see the green tru your wheels.
you can use high heat paint (regular paint can work too but it will not be as resistant) to paint your calipers.
Old Nov 24, 2004 | 06:54 PM
fsttyms1's Avatar
Green stuff rotors??? you mean the pads?? if you ae worried about the small amount you can see just wipe them down with a cleaner (soapy water-dawn) and then tape off the pad surface. then hit it with some black high temp paint
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
