GPS Antenna Install?
So from the TL Radio Cavity you ran the cable behind the dash out to the drivers side, emerging somewhere around the fuze panel and then on to the top of the dash? Trying to determine the routing you used.
That's exactly it. Back of the radio cavity > Driver's side, snaking around the steering column > fuse box > Around the fuse box right up against the wall > up the wall, following the edge line of the dashboard > emerges at the front driver-side corner.
The back up camera was no problem. I used a license plate cam and I ran the wiring down the passenger side, trying the reverse trigger into the passenger side reverse light and grounded on the metal under the panel in the trunk. The wiring from the camera just goes straight up from the bumper - no drilling required.
SiCrew
10-11-2003 11:54 AM
