Getting ready for a weekend project, looking for some pointers
Old Jul 11, 2008 | 10:41 AM
03S-typePenguin's Avatar
Arrow Getting ready for a weekend project, looking for some pointers
So I'vd got an 03 TL type-s and just bought new front rottors, pads, and a set of Eibach Pro-kit springs. My boyfriend is doing the work for me, but before we get started we are looking for help on what to look for. Are we going to run into any known problems with the installation? Know any short cuts? Any help and sudgestions will be greatly appreciated. Thanks guys/girls!!
Whoo! I'm glad I've got my first post out of the way!!!
Old Jul 11, 2008 | 10:48 AM
NJ Aegean 03's Avatar
When doing the rotors, make sure you have an impact driver handy (can get one at a local auto parts store). There are set screws that hold the rotor in place and they can sometimes be a PITA to remove; an impact driver makes short work of this.
Good luck and post pics of the new whip before and then after the work is completed!!
Old Jul 11, 2008 | 10:54 AM
c0v3rr1d3's Avatar
or a drill to drill out the screws, if they are really rusted in there. Also having a secondary jack handy helps with the shock/spring removal so u can jack up the suspension to allow some maneuverability.
Old Jul 11, 2008 | 11:09 AM
Hey guys, thanks for the tips, keep 'em coming! Do you think I could rent an impact driver from Autozone like I did the spring compressor?
Old Jul 11, 2008 | 11:19 AM
LukeaTron's Avatar
It costs $15 - $20. Just buy it. It's a good tool to have around for stuck bolts/screws. I use mine regularly.
Old Jul 11, 2008 | 12:35 PM
Bearcat94's Avatar
AZ Community Team
- Use some Liquid Wrench on those pesky retaining screws a few days, then a few hours, before removal. Then Impact Driver FTW ($25 at Sears; maybe a freebie loaner at AutoZone).
- Impact Driver on the Retaining Screws: 1 or two whacks!! in the "tight" direction to break loose rust, then 1 or two whacks!! in the "loose" direction to start them turning out.
- You'll need a Spring Compresser and Torque Wrench - Freebie Loaners from AutoZone.
- Spring perch/ Shock tower have to be properly aligned. See the DIY/Service Manual Scans below. You can REALLY F things up if you don't do this correctly.
- You don't need to Hammer the Rotors off. Some Liquid Wrench and a couple of M8 x 1.25 bolts is all it takes - see the DIY below.
- Check and/or print the following DIY's:
https://acurazine.com/forums/religion-politics-18/world-opinion-132940/ - Brake Replacement Service Manual Scans (3G). 2G is nearly identical.
https://acurazine.com/forums/ramblings-12/need-help-math-question-161652/ - Great 2G DIY Brake Rotor & Pad Replacement with Pics.
https://acurazine.com/forums/car-parts-sale-361/fm-modulators-group-purchase-173827/ - Shock/Spring Replacement Service Manual Scans (3G). 2G is nearly identical.
https://acurazine.com/forums/ramblings-12/shelf-life-whisky-164323/ - GREAT!! 2G Shock/Spring Replacement DIY with Pics.
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
tsx_boy
Dec 13, 2019 08:33 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
lanechanger
Oct 13, 2015 10:56 AM
samson_420
Oct 8, 2015 01:47 AM
