gauges
It will fit but your TCS light won't work because the VSA light on the TypeS is in a different spot. You're better off putting in a reverse indiglo gauge, much cheaper, looks as good as a type-s, and all the lights work.
Originally posted by Dark DJ
whoa, those indiglo guages look phat...can u gimme more info bout em, cost, installation etc. etc. awesome man, thankz
dark dj
dark dj
Use the following link to remove the gauge cluster. http://www.acura-tl.com/faq/faq.php#8c
Then take out the glass part and slide in the indiglo gauges, just be sure not to pop out the needles or you're screwed, it hard to recalibrate some of those needles. Use the double sided tape provided to screw the gauge to the stock gauge. Reinstall. Then wire the ground, an connect the positive to #3 plug on the back of the fuse panel. Everything is plug and play. I won't recommend letting some1 else install it, they might pop the needles off.
Originally posted by BiggyMcWang
The indiglo you showed looks great. Is there a version for the Type S? I've never done the electrical stuff on a car yet so I don't know jack about how to install them.
these are reverse, they have a blue back ground, it can switch to the greenis color, i can change the # color or just light up the #'s or just light up the back ground. as far as where can you get them? i bought them off a member who never installed them
damn, those picz are of just one gauge? oh im gettin those fsho..
dark dj
dark dj
There was a group buy only for 50 members last year (or year before?? ) and the company only produced 50 gauges.
Originally posted by songoku
Good luck getting that gauge because that's discountinued.
Re: gauges
Originally posted by john32
i want to put a 2002 type s gauge set in my 99 acura. Will it fit and where can i get one? I would also like to know where i can find a good lookin gauge cluster.
what company was it?
Go here for more info
http://www.acura-tl.com/forum/showth...&threadid=6587
http://www.acura-tl.com/forum/showth...threadid=30068
i was one of the lucky 50..
i got a 2003 TL type S gauge working on my 2003 TL - P . I wired up the TCS light to come on with the VSA and the exclamation mark.
so you can get a type S gauge working perfectly on a non type S TL.
Through out the whole time, I thought you had Type-S, Steve.
Originally posted by 04AcuraTL6speed
What i just realize is that the other difference is the red line for Type-S is 500 rpm higher. You can red line it longer.
Jul 16, 2017 07:33 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
