Gas Pedal Difficult to Press
superunknown
I apologize in advance if this is a stupid/novice question....
For the past two days, the gas pedal on my car has been acting very weird. It's as if there is a brick underneath it (I checked already to see if the floormat was stuck ) - even when I am on the highway going around 75-80 mph in D5, when I press the gas pedal, it almost physically doesn't go down.
It eventually accelerates - there is no jerking or hard movement, but it takes forever for the car to go from 50 mph to 80 mph on a highway, instead of the usually quick accleration that I experience once I am around those speeds.
Any ideas? I am driving a 2003 TL w/40K on it.
Thanks!
Thanks!
06 Anthracite TL
Get your throttle body cleaned out, or geta spray can of Gumout (or its equivalent) and do it yourself. My pedal was sticking when I would first accelerate- when I had the tranny oil kit put on, I had the Acura tech check and he sprayed the throttle body and linkage. Ther was a lot of carbon on the throttle body, making it stick. It worked for me.
SidhuSaaB
05-30-2020 12:40 AM
soupi
14
11-15-2015 11:15 AM
