funky idling
Old Jun 30, 2003 | 12:12 AM
fortunate's Avatar
Angry funky idling
I've recently noticed that my '02 TLS has some funky idling.
If I'm stopped at a light or just sitting in "parked", my engine will start stutterring just a little in a constant rythym. The engine hasn't completely died yet. This happens regardless of the engine temperature. Even after driving 30 miles, it'll still idle funny. I've also noticed that it does this regardless of the AC.
Anyone experiencing this? Anyone know what could be causing it?
Thanks.
Old Jun 30, 2003 | 12:27 AM
Kam
Yes, and it is scary I got 18600 miles and I get at times. I told the dealer about it and after hearing about all these lovely trannies we got, and they said nothing wrong!!! I said WTF... They told me to bring it back in when it happens MORE FREQUENTLY, so that our technicians can know what I am talking about..
my 2 pennies
Old Jun 30, 2003 | 12:36 AM
fortunate's Avatar
Yea, I'm at 22000 miles right now. I think I remember reading somewhere that this was a timing belt issue. Only thing is, I can't figure out why a timing belt issue would cause a rythmic stutter in the engine.
Old Jun 30, 2003 | 09:16 AM
yield2s's Avatar
It's carbon build-up in the fuel injection system. I had the exact same thing recently. You might find it's 10x's worse after the car sits for 2 or 3 days. Use a good fuel inj cleaner every 7.5 to 10k miles,or use Chevron fuel and you'll be fine.
Old Jun 30, 2003 | 10:22 AM
fortunate's Avatar
Cool, can u suggest any fuel injection cleaner in particular?
Old Jun 30, 2003 | 11:44 AM
yield2s's Avatar
not really, "greese lightning" worked for me but others recommend some stuff you can only get at dealerships,i think tecron is also good. but im almost poss.this will solve your idleing prob. and if not, could have used it anyway.
side note: just drive it normally with the cleaner in it DON'T RACE IT!
Old Jun 30, 2003 | 02:04 PM
FugittiveTLS`03's Avatar
2005 SSM/EB/5AT/Navi
A couple of weeks ago Mine was Idling funny but it aslo was not sifting right either....So i took it to the dealer and they said it was the TPS (Throttle position sensor) Thankfully they said Tranny looked alright, but to monitor the idiling problem. hasn't done it since
Old Jun 30, 2003 | 06:06 PM
fla-tls's Avatar
On the way!
Probably the best (if you can find it) is BG 44K. You'd have to call around to dealerships to see if they sell it, since it's not sold in stores.
Other than that, anything with Techron in it is also good. Two brands that come to mind are Chevron Techron (obviously) and STP Complete.
I've used both - and they're both good.
Old Jul 25, 2003 | 11:06 PM
nicksan's Avatar
Hi folks,
I am about to buy a 1999 3.2TL.
Did a cold start and I heard the idling problem...like it would surge in a rhythm for like 4 or 5 times then go back to normal, then repeat itself again.
After we filled it up with gas (gas light was on) and test drove it, it no longer did that.
Do you think I have the same problems.
1 mechanic told me it might be a Oxygen Sensor problem. He also ran a diagnostic thing, plugged in by ash tray and he got some error code P0420 Catalyst system efficiency below threshold message. He said that it's related to the O2 Sensor and that it is nothing too serious.
I spole to another mechanic and he said it might be the Idle Sensor...
Called Acura Service center up and they said it must be some kind of sensor acting up.
Old Jul 27, 2003 | 02:28 PM
maxx96's Avatar
New Life
I agree with fla-tls, STP complete system works great, I had a '96 Maxima and I use it as recommended every 4 to 5k miles and I never have to mess with injectors at all, also you never mentioned what brand of fuel you use, I always use Chevron or Exxon, avoid all the cheap gas, our cars are great on gas, should be no reason to put cheap gas in it. Also it is true that if you have problems with the throttle position sensor, you will experience this problem.
Old Jul 27, 2003 | 03:42 PM
PeterUbers's Avatar
'02 Type S here also .. have the same problem ...
mine if very minor, but if i sit and stare at the tack and listen to the engine w/ the windows down in the driveway .. i can hear the rhythmic stuttering ..
i guess i'll just wait 'till it gets pronounced enuf to take it in
DerrickW
Nov 15, 2015 05:52 PM
012TL-GLM
Oct 5, 2015 06:32 AM
Skirmich
Oct 1, 2015 12:59 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
