Fuel pump questions
Fuel pump questions
Have a 2000 Acura 3.2 TL with 245801 miles on it! Many times in the last six months I would be driving and the engine would click and totally cut off but the electrical power would stay on. After stopping safely I would turn key to be able to put the gear shift back into park so I could try restarting. It would turn the starter just fine put no fuel going to engine. After a few minutes of shut down it would usually start back up. This happened at 70 miles an hour or 15 miles per hour.
So I purchased a new fuel pump kit and just completed that process in the trunk. Everything has been great for one week! Just happened last night. I think this is the dam fuel relay switch. This is under the drivers dash? It also has a fuse correct? Any body done this before? Let me know? Thanks
Everything there is to know about your Honda/Acura main relay:
How the Main Relay works
When the Main Relay goes bad
I usually want OEM (original Honda/Acura) parts, so I would check around for Honda wholesalers.
For non-Honda parts, I first check with rockauto.com.
But I successfully reflowed the solder on my original PGM-FI relay (aka Main relay), and it has not acted up for three years.
adam83
Apr 21, 2020 05:21 PM
Pride96
34
Sep 19, 2016 10:58 AM
Brad2Taylor
1G TL Problems & Fixes
Jun 20, 2016 10:41 PM
Rob_TL
20
May 25, 2016 01:43 AM
