Fuel pump question
Old Oct 26, 2022 | 09:54 AM
2Quik's Avatar
Fuel pump question
I am looking for a fuel pump for my 2002 Acura TL and looking at rock auto at what is available but none of the available OEM / Interchange Numbers: match what Acura has as OEM part - 16010-S84-A01.
The parts I am looking at are DENSO 9500161 Includes Strainer and the DELPHI FE0479 Electric but I not sure they will fit.
If I order it through Acura, does it have all the parts, seal, float, etc. Is just a simple replacement or do have to remove certain things from the old pump and put on the new pump?
Thanks, any info would be great.
Old Oct 26, 2022 | 11:11 AM
2Quik's Avatar
The part number I provided was for the fuel filter, my bad. Fuel pump is17040-S3M-A00
Old Oct 26, 2022 | 12:58 PM
OEM part # 17040-S3M-A00 is at the bottom of RA's DENSO 9500161 assembly link below.
More Information for DENSO 9500161 (rockauto.com)
Old Oct 26, 2022 | 01:01 PM
I'd do DENSO without hesitation
Old Oct 26, 2022 | 03:29 PM
2Quik's Avatar
How can I test the connect at fuel pump? might also be the PGM-FIAcura 39400-s84-003?
Old Oct 26, 2022 | 04:42 PM
It's 20 years old if original to the car, why not replace it?
If you do, make sure to get OEM from Acura / Honda to be safe. Not a 'knock-off' from Amazon or Ebay.
Good Luck
Old Oct 26, 2022 | 06:40 PM
Jon M's Avatar
If you have the right connectors you can apply 12V to the fuel pump connector and hear the pump run. It will also run for a second or so when you turn the key to the on position, You can have someone turn the key while you listen in the trunk use a screwdriver handle to your ear and touch the metal end to the fuel filter top and you should be able to hear the pump come on.
Mylena Metcalf
1/2G MDX (2001-2013)
Sep 24, 2019 06:10 PM
Alexuyyh
1G TL Problems & Fixes
Sep 10, 2018 12:27 AM
Sly Raskal
Jun 4, 2007 05:20 PM
DRSS
1G TL (1996-1998)
Feb 5, 2007 03:59 AM
jucee187
May 16, 2003 11:59 AM
