Fuel pump?
Old May 29, 2008 | 04:46 PM
cobalt107's Avatar
Fuel pump?
Do you have to drop the fuel tank on a 99 tl to replace the fuel pump?
Old May 29, 2008 | 05:17 PM
fsttyms1's Avatar
no. I cant remember off the top of my head if its accessed through the trunk or from under the back seat
Old May 29, 2008 | 05:19 PM
swalch@stanford.edu's Avatar
I think there is an access panel in the trunk.
Old May 29, 2008 | 05:47 PM
Just checked. Yes the access panel is in the trunk, under the spare tire. You have to remove the assembly from the gas tank and then replace the pump portion. The new pump should come with instructions. It looks like there is a length of tubing to connect up and an electrical connector.
Old May 29, 2008 | 06:09 PM
cobalt107's Avatar
Thank you for the help.
Old May 29, 2008 | 07:11 PM
01tl4tl's Avatar
disconnect the battery NEG terminal before working on the gas tank and pump electrical connections
NO Smoking either!!
Old May 31, 2008 | 08:30 AM
1st timer's Avatar
UB6IB9
what about the fuel filter,where is it located on a 00 TL?
Old May 31, 2008 | 11:44 AM
01tl4tl's Avatar
on the fuel pump
IBankMouse
Jun 13, 2020 12:53 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
