Front and Rear lower tie bar...
Looking to install these two but what is the torque specs of the bolts?
I had put on the rear lower tie bar for a friend a while back and I believe we used bout 80lbs/ft. It was hard to get the lower control arm to line up well but it appears even after he got the alignment, it still slightly pulls to one side.
Any recommendations or suggestions when I install mine?
Thanks!
Thanks!
Originally Posted by TLMugen
OK Bxscig,
I checked the manual and for the nut that's circled, it says 40 ft-lb:
![](http://img78.imageshack.us/img78/3528/rear0gn.jpg)
Is that the one you want the torque spec. for?
did you paint the bottom of your car?
what paint is it?
I'd rather be driving:
That pic is old so the underneath of my car is a little dirtier now. I bought the car used and I was so anal that I used the black rubberized undercoating to undercoat the car and make it look new
I painted the exhaust with DupliColor Hi-Temp primer and then Hi-Temp flat black (the flash made it come out shiny in the pic). I was anal to mask the sway bar because I wanted to keep it Eibach red
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Originally Posted by Bxscig
Yeah that is the one I needed. Thanks! Do you have the one for the front?
OK, the front; which bolt/nut do you need the torque spec for? I'm not sure which one you're talking about
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
09-04-2015 08:03 AM
