Front Lift point bent
Old 07-09-2015, 04:33 PM
JDMEXI's Avatar
So I lifted my car from the front lift point after awhile I noticed it was slightly bent. Can this cause any problems? Thanks
Old 07-09-2015, 05:21 PM
TLer trash's Avatar
It probably won't hurt anything, but you can straighten it out easily. I've only had one bend on me, and I straightened it out with a crescent wrench.
Old 07-09-2015, 05:41 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
are you using jackstands to support the car? or leaving all the weight concentrated on the lift point?
Old 07-09-2015, 06:12 PM
JDMEXI's Avatar
I had a jack stand but the car wasn't sitting on it. So yeah, the weight of the car was concentrated on the jack point
Old 07-09-2015, 06:35 PM
JDMEXI's Avatar
So you just hit the sh*t out of it?
Old 07-09-2015, 09:08 PM
01tl4tl's Avatar
crescent wrench implies he set it to fit the metal, then pulled on the tool
Next time place a small piece of 2x4 on top of the jack to spread the load
TLer trash (07-10-2015)
Old 07-10-2015, 12:37 AM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
Mine also bent ages ago... Now I just use the sub-frame with a ply of wood in between. Works wonders and feel safer.
Old 07-10-2015, 04:33 PM
SuperGreg's Avatar
I jack the car up from the front lift point and use jack stands under the side lift points, where do you guys put jack stands otherwise?
Old 07-10-2015, 06:30 PM
Skirmich's Avatar
^ I use the chassis frame to put the jack stand.
peti1212
ILX
22
01-05-2022 05:14 PM
nsl752
14
12-06-2016 07:32 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
08 NBP TL
09-08-2015 08:49 PM
Quick Reply: Front Lift point bent
