Front engine mount just installed but...
Old Apr 24, 2012 | 09:18 PM
huynh919's Avatar
Hi,
I just installed my front 99 tl with Anchor 9185 but doesn't have a hydraulic tube. Is it okay? I clog up the tube and let it hang there.
Thx.
Old Apr 24, 2012 | 09:21 PM
MilwaukeeDave's Avatar
Yes I was told to cap the line airtight so no leaks then cable tie it down so it won't hang or interfere w anything.
Old Apr 24, 2012 | 09:26 PM
Skirmich's Avatar
You must just Insert something into the Vacuum Line so it will have no Leaks, No Worries.
Old Apr 25, 2012 | 08:07 AM
fsttyms1's Avatar
This is the correct thing to do with the performance mounts like you got, but for those buying the oem style replacements i would personally not use the mount if it didnt have the vacuum connection and get one that does. Seeing its already installed, yes just plug the line and place it out of the way.
Old Apr 25, 2012 | 09:54 AM
huynh919's Avatar
Thanks guys.
It took me 1 hr 30 mins. To swap that out. What i did wrong was jacked the car only one side up, not evenly raised the engine, should save lots of time if i got the 14mm gearwrench.
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
drone619
Jan 26, 2016 07:09 PM
08 NBP TL
Sep 8, 2015 08:49 PM
leerbgdup
Sep 6, 2015 11:01 PM
