Front Ball Joint
Old Sep 4, 2007 | 11:18 AM
op_garyy's Avatar
5th Gear
Front Ball Joint
Just found out I need to replace my front ball joints. Is it possible to do it yourself and how would i do it if it is?
Old Sep 4, 2007 | 02:42 PM
acutee's Avatar
It should be straight forward task. Buy or loan a balljoint remover, and a 36mm socket for the front axle nut. The axle nut is very tight so you will need a breaker bar to help leveraging the force.
Old Oct 18, 2007 | 11:31 AM
acitydweller's Avatar
how did you verify that your balljoints were in need of replacement?
Old Oct 18, 2007 | 01:07 PM
fsttyms1's Avatar
torn boots, play in them, clunking noise going over bumps
Old Oct 19, 2007 | 09:58 AM
op_garyy's Avatar
5th Gear
An Acura dealership next to my house told me i need to replace it, and i do hear a noise when i turn on the right side. Also, kind of unrelated, but recently my car began to hesitated a lot more than usual, sometimes i would press the gas for like 2 seconds and the car would not respond then it would jerk and go. I heard that it could be the computer or my trani is about to go, does anyone know what it could be?
Old Oct 19, 2007 | 11:21 AM
acutee's Avatar
How long have you changed the fluid? Try to drain and refill and see if it makes any difference.
Old Oct 19, 2007 | 12:40 PM
op_garyy's Avatar
5th Gear
i change the trani fluid about 15,000 miles ago. Before that I waited longer to change it and the car was running fine. Sometimes I hear a "clank" right before the car jerks.
jblessing
Aug 8, 2018 09:43 PM
marcelft
Jul 10, 2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
jblessing
Wash & Wax
Sep 17, 2015 09:28 PM
08 NBP TL
Sep 8, 2015 08:49 PM
