FOGLIGHT w/BODYKIT
FOGLIGHT w/BODYKIT
I know the whole foglight thread has been done to death but I did a search and got the instruction for install. In the instruct. it says to take of the nuts under the fog lights and pop them out with screwdriver etc. Problem is, I've got the OEM body kit and it blocks access to under the foglight where the nut would be.
Is there another(relatively easy) way to install?
Any help much appreciated!
I don't know.....I know I bought some bulbs and I have the OEM kit too, so I guess we are in the same boat..............I'll probably go to the dealer, my buddy will intall for free.........
I have the OEM bodykit as well. I was attempting to remove the fog light housing, but wasn't having trouble getting it out. I was also being very careful and afraid I might break the plastic housing. I finally remove the bottom splash guard by removing one 10mm bolt and 2 plastic clips. I reached in and grabbed the light from behind, change it and then put everything back together. All together took me about 15 mins.
I have the bodykit too and I have no problem in replacing the fogs. If you go under the bumper, you should see 2 holes that you can stick a 10mm socket wrench and unscrew the bolt. Shouldn't take more than 5 minutes.
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
shinybluecls
Nov 16, 2005 12:00 PM
ST2000
Aug 14, 2003 02:47 PM
Good luck.
