Foglight trouble, could it be my mod?
Well both my fogs have been burned out for a couple months. I use those cheap Max bulbs and they do blow every 6 months or so. Well today I finally picked up another set of bulbs. The old ones do not look blown to me. In addition to that, my left fog harness(the white plastic piece) is half burned away. Well I cleaned it up and installed the new bulbs anyway. They work fine?????
Could this be happening because of my re wire mod? The bulbs are 80W.
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Wow, what exactly did you rewire? Sorry if it's obvious, but I'm new here...the only fog light mod I know if is hooking the switch up so it will activate with the parking lights.
I think stock are 51Ws but 55W is close enough hopefully not to do any damage. A lot of other people have said that putting in 80Ws have caused harness melting and some haven't.
Ur wiring is burnt! I had that happen to my in my previous accord. Your going to find out that the bulbs now are going to keep blowing out on u even quicker. I was at a point where I was changing bulbs by the week. U should go ne more than 55W with that harness.
did you by chance let your car sit alot w/ the foglamps on just cooking away at the harness?
If anybodys interested in making their bulbs last longer, check this out. after dealing w/ 3 pr of burnt out bulbs in 4 months i was pissed. I noticed though that my pass side bulb was burning out much faster than the drivers side. (oh ya i have them on for 2 hours everyday) I started to instect the housing and everything seemed fine except the metal heat shield around the bulb was slightly "shrunk down" smaller around the bulb on the pass side. This lead me to believe that this was aiding in the premature burnout of my bulbs. and since it was time to do my plexi glass conversion, I removed the shield on one side and left it in on the other. I had to make sure by removing the shield i wasnt going to be blinding oncoming traffic.
So i parked it in the street and checked, It was not anymore anoying then the side with the shield.
That was 3 months ago and i havnt replaced a bulb since.
Don't take my word for if you dont want, but if your replacing you broken lens and want to remove one and see, go for it.
Just my 2 cents.
Re: Foglight trouble, could it be my mod?
Does anyone know the wattage of a 97 CL or Accord headlight bulb? I wonder if I could use those sockets. I had these same bulbs I use in my fogs in my 97 CL for a year and a half no problems.
This stuff is not a "maybe it will happen or if it will happen" IT WILL HAPPEN.. just a matter of time.
"JUST MY 2CENTS"
"JUST MY 2CENTS"
I love it. Is this stated as a "matter-of-fact" or maybe your 2 cent as you admit?
I use my fogs 2 hours min everyday. It's been months since i remove the light shields, and have monitored the progress often. so far so good.
Also, did u do the plexi/lexan conversion for ur fogs? If not, ur metal filings in the housing will start to chip away , but ur glass won't brown spot. There are many people who have experienced this already over at the WORLD ACURA forum (switch words).
Acura isnt stupid, they wouldnt put a heat shied in there for no reason. People who removed it were under the impression that it was a scatter shield. That is why they did it.
Good Luck.
quanaman
01-09-2023 07:33 PM
InFaMouSLink
10-27-2015 06:52 PM
