Fog light mod (Alternate version)
Old Apr 27, 2011 | 06:09 PM
  #201
Neejay's Avatar
Does anyone have any problems with one foglight not turning on until you turn them off and back on again? Or if you turn them off and back on, the other turns on and the original one turns off? Then you have to keep pressing the button on/off in order for both of them to turn on...
I bought a foglight relay kit on ebay, but it does the same thing. I'm thinking that the foglight switch needs a constant +12v source that doesn't get cut when turning on the car.
Old Jun 14, 2011 | 03:12 PM
  #202
KatabaticSaint's Avatar
Just did this in 10 mins with spare stuff awesome DIY, any specific fuse i should put it in?
Old Sep 17, 2011 | 01:06 AM
  #203
trackvaulter01's Avatar
Originally Posted by Los510
yea im going to check on bay today. But i guess im going to have to custom fit and wire some hids in there. Any suggestion on how to wire them? I know im going to have to get power from the battery directly with a relay. But any suggestion on how to turn them on/off? Maybe i can use a TL fog switch somehow?
I have a '01 CL and just ordered HID projector fogs to retrofit from theretrofitsource.com I just ordered a TL switch online and am going to wire the lights to the switch, I havent decided if I'm going to disconnect the roadlamps and install them there or just install them right next to them though, but I'm just going to follow the instructions on this thread. The foglights i ordered come with a harness and everything so it should have everything I need *fingers crossed*
Old Sep 20, 2011 | 06:38 PM
  #204
blackuraTLS's Avatar
Originally Posted by Bxscig
This is for the 02/03 TL Models.
Here is the pinout/wiring color code for the fog light switch for the 02/03 models.
I had tested the states of these wires under the following conditions:
Blue w/ Red stripe = +12V when button is pushed and headlights are on
Whie w/ Red stripe = +12V when headlights are on
Red w/ Black stripe = +12V when parking lights are on
Provided by Pianoman41
1. White/Blue - Ground side of indicator light (green light that shows fogs are on)
2. Blue/Red - Power to passenger side footwell relay
3. White/Red - Power from headlight switch
4. Red/Black - Power from taillight relay
5. Red - Connection to dash light brightness controller
Now the fog light mod has the white/red and the red/black tied together. I assume that by hooking these two together, it fakes the switch into thinking that the headlights are on so that you can turn on the fogs. NOW! What if you want the fog lights on without the parking lights on??
Would the solution be to supply the white/red wire (headlight switch) +12Vs? Possibly from a source that is HOT when the key is in the ignition?? Will the white/red wire be enough or will the red/black wire also have to be supplied 12Vs?
One more question, if that solution suggested above works, should diodes be inserted?
Azn.m3nace and I just did this to my 02 type S!!!!! Thank you so much for the thread
Old Sep 21, 2011 | 07:42 PM
  #205
I just got my TL fog light switch and Blazer fog lights.
Im so completely lost on how to do this...hoping retrofitsource emails me a good how to pdf for the install!
Old Sep 21, 2011 | 08:04 PM
  #206
pickler's Avatar
i tried this and caused a short and blew a few fuses lmao. i'm gonna stay stock haha. i'm a noob.
Old Sep 21, 2011 | 08:32 PM
  #207
so after watching this video
http://www.youtube.com/watch?v=dvdvbylYZc0
I believe I don't have that white connector thing that goes into the TL switch any idea where i can get that?
Old Sep 21, 2011 | 08:37 PM
  #208
03tLsNBP's Avatar
MechEng
You could probably find out on the CL side. Im sure many CLers have done the TL fog light mod.
anyways here's mine. i did it a while ago.
Old Sep 21, 2011 | 10:08 PM
  #209
It was easy to do, we messed up by putting the diode in backwards lol, but it was straight forward, i'm about to by HID fogs then switch back LED turn signals. SO PUMPED
Old Sep 22, 2011 | 04:42 PM
  #210
found the harness at a junkyard for $15...now to install and figure this out...
Old Sep 23, 2011 | 03:36 AM
  #211
AZN.M3NACE's Avatar
USDM -> JDM
i did work for blackuraTLS
Old Dec 14, 2011 | 06:45 PM
  #212
vtec260's Avatar
Wow...such an easy mod. Too bad I got raped on the prices for add-a-circuit and diodes.....ended up paying $20 for both parts. But I blew $20 for something stupid before, so this was money well spent. Initially had problem when I didn't push Tap-a-tap hard enough to make a solid connection. Once that got figured out, it was easy. I would probably prefer to run 6000K HID fogs for DRL and turn factory DRL on high beam off. Any suggestions other than pulling out the fuse for DRL?
Old Jan 14, 2012 | 10:37 AM
  #213
jauman's Avatar
Super old but updated... works better than it did before. Now you can have your fogs on and crank w/o them shutting off.
Instrumental Panel Fuse # 9 Driver side to Add-a-circuit to diode to white/red wire on the harness on the fog light switch.
You could also use these for DRLs if you like since the parking lights dont come on with it.
What is the diode for? Where can you buy them?
Old Jan 15, 2012 | 07:32 AM
  #214
Hondanutty's Avatar
Buy them at Radio Shack, they keep the current from feeding backwards through the circuit.
Old Jan 15, 2012 | 10:44 AM
  #215
vtec260's Avatar
He is located in Japan so maybe no Radio Shack? But since Japan is electronic mecca, probably not hard to find. Ebay is also a cheap option if can't find locally as a lot of vendors sell 10 diodes for like $5.
Old Jan 28, 2012 | 02:55 PM
  #216
HairyMonkey019's Avatar
for anyone doing this mod
http://www.ebay.com/itm/330582636062...#ht_500wt_1361
or contact melder215@yahoo.com
for diodes.
BEST PRICES ON EBAY!!!!
I bought from this guy already. $2 for 12 1n4004 diodes is awesome.
Old Jan 28, 2012 | 03:05 PM
  #217
assclown's Avatar
2000 acura tl FPR
that is the rustiest dash I've ever seen lol
Old Jan 28, 2012 | 08:42 PM
  #218
vtec260's Avatar
I said same thing to myself re:rusty dash. Mine looks pristine compared to that, but it's so dry here.
Old Jan 29, 2012 | 07:47 AM
  #219
jauman's Avatar
what i'm wanting to do is to use the reverse lights as back off warnings. I want to use the same bulb as the one that operates when the car is in reverse, for the ones that i can push a button and they will shine also. My concern is that If I power the lights with alt power that the power will back up the factory wiring to the computer and tell the car that the bulbs are on and the car is not in reverse. Would these diodies (if installed inline) keep the current from going from my alt power source back down the factory wiring?
thx
Old Aug 29, 2012 | 03:08 PM
  #220
shaddyprynce's Avatar
wow i took my time reading all of the pages but i just want an easy way out of it and how can i do it...? like so simply which can be done in 5 mins or something?? help
Old Aug 29, 2012 | 09:47 PM
  #221
Skirmich's Avatar
This can be done in 5 Min or Less.....
This is In NO WAY Difficult even for someone who doesnt know his stuff around electronics, There isnt even Soldering Involved.
If you think this is Difficult DONT EVEN TRY IT!!!
Old Aug 30, 2012 | 08:33 PM
  #222
lol ok no i did it it worked fine but then when i try to do mod my side markers my parking lights dont work... and when i lock my car the light are not working need help asap ...
Old Oct 6, 2013 | 11:32 PM
  #223
Xxb005txx's Avatar
Gabriel Alejandro Iser
Post
woah...literally went through this whole thread.. im thinking about doing this mod down the line once i learn where my harness runs through an stuff. not so knowledgeable in these arts my 03 tl-p only came with one oem fog lamp. i bought it used. problem is that it doesnt have wiring connected to the lamp or even dangling. i ordered yellow fogs from ebay but they dont come with wiring harness. would i need to buy one or could my wires be somewhere under my hood?
Old Oct 7, 2013 | 07:49 AM
  #224
fsttyms1's Avatar
FIRST thing you NEED to do before going out and buying stuff or us being able to tell you anything is to inspect the car for the missing foglight wiring. You may have to take the front bumper off to really look. Front bumper comes off in 5 min or less.
Old Oct 7, 2013 | 05:22 PM
  #225
Xxb005txx's Avatar
thanks but i finally...quote.. FINALLY found out what was goin on. its pretty ironic actually...the lamp i had...had no wiring or ground cable..but the missing lamp socket did... o.o but now i got both harnesses n the power is up n runnin, now i just wait for my fogs to come in n ill install!
Old Nov 3, 2013 | 02:51 PM
  #226
KyleT's Avatar
I just did the fog light mod where you swap the two wires on the switch. I just want the fogs to come on with the parking lights and headlights so thats why I just did that mod. Everything works great, but only problem is the green light on the fog light switch doesn't light up when the fogs are on. Not sure why.
Old Nov 4, 2013 | 06:38 PM
  #227
KyleT's Avatar
Anyone know?
Old Nov 4, 2013 | 08:22 PM
  #228
victus1's Avatar
The indicator light on the switch has to do with pin 1.
Pin 1 (white/blue): Connects to ground. And this terminal goes to the (-) side of the indicator lamp inside the switch, to complete the circuit.
The + side of the indicator lamp gets its voltage from pin 3 (white/red) which you already connected correctly since this powers your fog lights.
Old Nov 4, 2013 | 11:02 PM
  #229
KyleT's Avatar
Hmm so is there a way to get the light to work with having the wires flipped?
Old Nov 5, 2013 | 07:50 PM
  #230
KyleT's Avatar
If I spliced power from the tail light relay into pin 3 and 4. Would the led in the switch work? And also be able to use my fogs with parking lights?
Old Nov 5, 2013 | 10:20 PM
  #231
victus1's Avatar
Power from the taillight relay connects to the dash light brightness controller.
You need Pin 1 to be connected to ground for the indicator light to work when the button is pressed.
Old Nov 6, 2013 | 08:07 PM
  #232
KyleT's Avatar
Then how come the light on the switch doesnt work after switching pin 3 & 4?
Old Nov 6, 2013 | 09:30 PM
  #233
victus1's Avatar
Because it doesn't have a closed circuit to make current run through the indicator light. It needs a connection to ground via pin 1 to complete the circuit. Look at the diagram in the Service Manual on pg. 22-157....you need to wire the switch like this to supply a closed circuit of current to the indicator light.
Old Feb 20, 2014 | 10:32 AM
  #234
DazzleLord's Avatar
Fog light mod diagram
Whats up people, I found this whole post quite difficult to understand and had to read it several times. I have made a diagram of how I understand this mod to work. Please look at it and let me know if it is right, and if so share it.
http://www.pascau.com/clients/Acuraz...ight%20Mod.pdf
Cheers
Old Feb 22, 2014 | 10:35 PM
  #235
Bxscig's Avatar
Looks good. Thanks!
Old Apr 22, 2014 | 10:51 PM
  #236
lexbeats's Avatar
4th Gear
Works as expected thanks guys...
Old May 31, 2014 | 04:13 PM
  #237
jneelddesigns's Avatar
I realize this thread is a million years old but I just bought a 02 TL and have started modding. I've looked and have been unable to find pictures/d.i.y. of how to get to the switches. The rest is pretty straight forward and I understand it. any help would be appreciated. Thanx
Old May 31, 2014 | 10:13 PM
  #238
Bxscig's Avatar
Remove the fuse panel on the left side on the driver side. There should be a screw there and under the dash near to obd reader there is another screw. I think after that it just pops right off. It's been 6 years or so since the mod and I haven't had to go back in there.
The switch you just push to pop out.
Old Jan 19, 2015 | 08:28 AM
  #239
losymis's Avatar
I jus tapped white/red to fuse box...drivers side #9...
Old Mar 11, 2017 | 06:10 PM
  #240
Billfromnj05's Avatar
3rd Gear
Anyone wanna help with this or live near me to help? Jersey or NY lol I don't like messing with electrical wires lol
