Finally doing a 6speed Swap
#43
Which one are you talking about? I have my regular one left an i already sold the 6-speed cupholder
#44
Sorry delay update:
My 6Speed Swap has been done for about 2 weeks now an it drive like a dream. I did have some major misfire on engine an that problem got solve, but left bad burn too my car. Phee know what I'm taking about. This Swap would have be done over 4 months ago if i didn't have to wait on Tranny mounted that seek to be on back order like forever.
First off I need to give Special THANK to Phee for introducing me to guys of Drive Automotive an that would be Alben an his dad Mr. Ruben without then this could never been done. Also needed to THANK, fsttyms1 an 6MTUA5 for there Parts list (This made this very easy to find all my parts i needed).
Last but not least Richie V6 for making Modules for TL. I can wait to get this part in my car this weekend
Will post some picture of final product 2nite
#48
Thank for all Congrat Guys
J32A2 with 04-06 TL tranny on the right side
Everything done an installed (i need to get engine cover )
Just inside look of new shifter an pedals
AN What Misfire did to my rear OEM Lip
A simple test drive on highway cause this. The bad thing was i had no Check Engine ON so i didn't know there was misfire until i switch back to my 99 gauge cluster
#53
#54
Here my parts list guys, I got most of my parts from Acuracarland@com
I doing this as updated an it may make it easier for the next 6speed Swapper
I also included Component area, item # an how many you needed
Parking Brake (MT)
#1, 3, 4, 6, 7
Rear Console(2)
#5 only
Shift Lever-2
#2, 4, 6, 8, 9, 10, 12, 16(2), 17(2)
You can go buy 10,12,16,17 at local part store
Engine mount
#5, 6, 8, 9, 13, 32(4), 34(4), 40(4), 41(2), 45(2), 47
Clutch
#3, 5(8), 6(6), 7, 9
Clutch Release
#2, 3, 5
Clutch Master Cylinder
#7, 9, 11, 13(2), 15, 16, 17, 19, 20, 21, 28(2), 29(2)
Check if your Tranny come with #9, 13, 19 (mine did)
Must Read:
#13 has Wrong part# on Acuracarland site.
Here Correct Part # 46941-S5A-003
Part# 17, 20, 21, 28, 29 (junkyard #17) an others at local part store
Only thing I did not included picture an parts # was pedals.
For Clutch an Brake pedals you can use parts off 98-02 Honda Accord Manual or 03 Manual Acura CL
Try get the hold Bracket assembly an not just pedals piece.
03 CL Tranny or 04-06 TL Tranny
Richie V6 Module
Parking Brake (MT)
#1, 3, 4, 6, 7
Rear Console(2)
#5 only
Shift Lever-2
Engine mount
Clutch
Clutch Release
#2, 3, 5
Must Read:
Richie V6 Module
#60
oopppsss....
On Acuracarland@com go to
Part & Service then Order Acura Parts Next Choose CL, 03, 2DR Sport or w/ Navi, KA6MT, (then given Component area)
This is area where i got all my picture from an you can see price on all the parts that's needed. I'm lucky they are in GA an they are local so I only had to pay for taxes an $5 handling charge b/c shopping cost for all this stuff is alot.
You can play around an just start adding all parts in shopping cart just to see final price for just parts alone.
#62
oopppsss....
#64
make sure you get the handbrake kit too.
get on richiev6's harness list too.
#66
#68
#72
yes, they match right up.
there would be quite a few modifications you'll need to do. lots of patience and some drilling skills
you prob could, but remember changing clutch and flywheel (if you have someone change it out later on) will cost you more than if you were to do it right the first time.
#73
Thank Assclown for answering all question for me
I have been busy working an trying finish up wiring from Richie Module.
Everything wire up great an only thing left is the speed sensor an reverse light. For guy with Type-S wiring harness your with be just plug an play on speed senor for us Non Type-S we are going have to make our own harness an add so more wire to Richie Module. But NO biggie at all. I will give you guys updated after i get done
#74
yeah man, give us a DIY on the richie harness, i dunno if it comes with instructions or anything. my swap time will be sometime late next month. all i need now are mounts and ECU. (and waiting to pay off my mod to recieve that)
#75
p.s.
I saw you new mod
AznWay (02-20-2013)
STL TL-S
09-23-2015 09:52 PM
