Filters
Old 11-15-2004, 09:00 PM
dee diddy's Avatar
Filters
I was reading over the Type 4 servicing and I saw:
24 mths/48,000 km Replace Air Conditioning Filter
just wondering if this is also known as the cabin air filter?
I'm just a lil confused cuz I also saw Replace air cleaner element. which I believe is for one in the engine, right?
Also saw Replace dust and pollen filter (if applicable)....now where is that (or do we have that filter??) and can I do that myself? A search on the site didn't pull up any results.
Thanks dudes.
Old 11-15-2004, 09:06 PM
Boomer SOONER
ou sig's Avatar
Thanks dudes.
the Cabin filter is inside/AC filte/dust and pollen filter...you can search for cabin filter on this site to find everything you need.
Air cleaner element is the engine air filter. I recommend replacing with a K&N filter now because you will never have to replace it again - just clean it, so it will pay for itself when you would have to buy a regular paper filter. And it flows more air.
Old 11-15-2004, 09:13 PM
dee diddy's Avatar
Sweet you just confirmed what I thought about the filters. Then I can cross out the dust/pollen filter and A/C filter off the Type 4 servicing list since I'll be changing out my cabin air filters myself in the next day or 2. Yep, I already have a K&N filter. I already change my own oil and rotate my tires too, so it looks like the only major thing I'll need the dealership to do is to service the brakes and everything else is just inspecting and hopefully that means not paying a too much.
Old 11-15-2004, 09:31 PM
Boomer SOONER
ou sig's Avatar
ya I really wouldnt worry about the dealer unless its under warranty or for major repairs or work, like a transmission. Everything else do yourself - if you can or go to another shop that can work on Honda/Acura, they are quite a bit cheeper there.
Old 11-15-2004, 09:49 PM
dee diddy's Avatar
actually i'm bringing it in tomorrow for the tranny recall thing...having em take a look at it. i thought since i'll be there i'd go thru the Type 4 (48k km) servicing since i'm at 46k km and cross all the stuff that i know how to do and ask the service advisor how much they'll still charge for the rest. so far this is my list:
Type 4
NO - Replace engine oil* and filter.
Service front and rear brakes.
NO - Rotate tires**, inspect for wear and adjust pressure.
Lubricate all hinges, locks, and latches with multipurpose grease.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect parking brake adjustments.
Inspect brake hoses and lines (including ABS).
NO - Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
Inspect exhaust system.
Inspect fuel lines and connections.
NO - Check all lights.
Inspect the underbody.
Inspect and adjust drive belts.
NO - Replace dust and pollen filter (if applicable).
NO - Replace air cleaner element.
Specific Additional Required Maintenance
NO - 24 mths/48,000 km - Premium Replace air cleaner element
Adjust only if noisy Inspect Valve Clearance
36 mths Replace Brake Fluid
NO - 24 mths/48,000 km Replace Air Conditioning Filter
rcs86
08-02-2016 06:52 PM
knight rider
03-04-2016 08:59 AM
LeVeL
10-18-2015 04:19 PM
steve
09-30-2015 09:23 PM
jmaxima03
09-27-2015 10:22 AM
Quick Reply: Filters
