Filters
Filters
I was reading over the Type 4 servicing and I saw:
24 mths/48,000 km Replace Air Conditioning Filter
just wondering if this is also known as the cabin air filter?
I'm just a lil confused cuz I also saw Replace air cleaner element. which I believe is for one in the engine, right?
Also saw Replace dust and pollen filter (if applicable)....now where is that (or do we have that filter??) and can I do that myself? A search on the site didn't pull up any results.
Thanks dudes.
Thanks dudes.
Boomer SOONER
Thanks dudes.
Thanks dudes.
Air cleaner element is the engine air filter. I recommend replacing with a K&N filter now because you will never have to replace it again - just clean it, so it will pay for itself when you would have to buy a regular paper filter. And it flows more air.
Originally Posted by ou sig
the Cabin filter is inside/AC filte/dust and pollen filter...you can search for cabin filter on this site to find everything you need.
Sweet you just confirmed what I thought about the filters. Then I can cross out the dust/pollen filter and A/C filter off the Type 4 servicing list since I'll be changing out my cabin air filters myself in the next day or 2. Yep, I already have a K&N filter. I already change my own oil and rotate my tires too, so it looks like the only major thing I'll need the dealership to do is to service the brakes and everything else is just inspecting and hopefully that means not paying a too much.
Boomer SOONER
ya I really wouldnt worry about the dealer unless its under warranty or for major repairs or work, like a transmission. Everything else do yourself - if you can or go to another shop that can work on Honda/Acura, they are quite a bit cheeper there.
Type 4
NO - Replace engine oil* and filter.
Service front and rear brakes.
NO - Rotate tires**, inspect for wear and adjust pressure.
Lubricate all hinges, locks, and latches with multipurpose grease.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect parking brake adjustments.
Inspect brake hoses and lines (including ABS).
NO - Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
Inspect exhaust system.
Inspect fuel lines and connections.
NO - Check all lights.
Inspect the underbody.
Inspect and adjust drive belts.
NO - Replace dust and pollen filter (if applicable).
NO - Replace air cleaner element.
Specific Additional Required Maintenance
NO - 24 mths/48,000 km - Premium Replace air cleaner element
Adjust only if noisy Inspect Valve Clearance
36 mths Replace Brake Fluid
NO - 24 mths/48,000 km Replace Air Conditioning Filter
rcs86
08-02-2016 06:52 PM
