Factory Sound System Question
Old 11-17-2009 | 11:24 AM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
Does/should the factory sound system head unit in a 2002 TL-S play CD/RW burned cds??? Seem liked I tried a burned cd when I first got the car and it didn't play.
Old 11-17-2009 | 11:32 AM
jjashaa's Avatar
Avant Garde Wheels
mine plays burned CDs....
Old 11-17-2009 | 11:47 AM
webmastir's Avatar
2003 TL
i've had problems with shitty Imation cd-rw's. other than that, it's been fine. thank God I discovered Blitzsafe.
to hell with CDs!!
Old 11-17-2009 | 11:58 AM
hANDYcaptd's Avatar
It's the Halladay season!
Mine does too...
Old 11-17-2009 | 12:49 PM
AlanW's Avatar
CD/R vs CD/RW ????
Could the problem possibly be from using a CD/RW disc instead of just a CD/R disc?? Pretty sure the one I tried was a CD/RW.
Old 11-17-2009 | 04:20 PM
gold2003tl (90)'s Avatar
2003 TL-p
mine used to play burn cd-r's, then it kept jamming and failed.
now i have a kenwood after market headunit, plays anything i put in it.
i really dont recommend putting burned cd's in the stock head unit, it has a history of jamming which many will complain about here.
Old 11-17-2009 | 04:28 PM
jjashaa's Avatar
Avant Garde Wheels
i've never had that happen. =]
i take my key and "shave" the edges so its smoothened and have no such stickers and sstuff as labels.
Old 11-17-2009 | 05:13 PM
hANDYcaptd's Avatar
^ I use to smooth the edges with a pencil.
Ipod adapter > CD's
Old 11-17-2009 | 08:29 PM
fsttyms1's Avatar
Aftermarket> factory
Old 11-17-2009 | 10:16 PM
klectic's Avatar
Mine plays CDR but only some CDRW's... for some reason it will play if there's less than 10 tracks on it lol but if I burn more than 10 it won't play.. strange..
Old 11-18-2009 | 01:39 AM
WDPTLS's Avatar
CD-RW usually won't work because I believe it burns differently and CD-RWs are made differently, specifically the burning layer. I would stick to strictly CD-Rs when making audio CDs. Also you may want to check you didn't burn the CD-RW as an mp3 CD rather than an audio CD. Meaning the burned as a .mp3 instead of a .cda.
Old 11-18-2009 | 09:37 AM
AlanW's Avatar
Thanks WDPTLS and klectic. I tried two different CD/RW and they definitely don't work. I'll try a CD/R and see if how that works-I bet that is the answer.
Old 11-18-2009 | 10:24 AM
WDPTLS's Avatar
No problem man, always here to give a helping hand. Just my way of returning the favor from all the help I received from fellow AZiners lol
Old 11-18-2009 | 02:15 PM
crazym0nkey's Avatar
For me, I tend to find that burning at low speeds helps play the CD better. Usually when I burn CDs at higher speeds, the later songs on the CD tend to have a static/scratching noise. I usually burn at 4x.
Old 11-18-2009 | 08:00 PM
iv4hcx3l4's Avatar
3.2 Type S
dont burn an mp3 cd cuz the stock deck cannot read
Old 11-19-2009 | 02:45 PM
AlanW's Avatar
Update
Burned an CD/R disc at 4X as an audio CD .cda last night and it worked
But on the downside, I discovered that for some reason, my driver's door speaker is no longer working now.
Old 11-19-2009 | 10:00 PM
'02_TL-S's Avatar
Traded in my
I've had CD-RWs work before. But the problem is with jamming which I think will happen to anY CD. I figured out how to fix it but the tiny springs that cause the problem are impossible to find and I've given up. Blitzsafe FTW!
Old 11-19-2009 | 10:06 PM
MrChanh's Avatar
i had to go with aftermarket. i had the stuck cd problem too. every other one was jamming. you'll love an aftermarket deck.
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
scionxb3003
10-02-2015 05:50 PM
Quick Reply: Factory Sound System Question
