factory alarm disable
they go wooooot wooooot
1 Post
hey guys,
long story short, i have a viper and sometimes the factory alarm will still go off for no reason when the car's unlocked with the viper remote. does anyone know how to disable or remove the factory alarm system? maybe by just pullin out a harness somewhere? thansk in advance guys...
sumbdy gettin used 2nite!
You could try this:
While your Viper is unarmed, lock the car with the factory key pad, then unlock it with that key pad, and stop using it. As long as the factory alarm is in disabled state it shouldn't have interaction with the viper.
If the installer did it correctly. Your aftermarket alarm should arm with your stock alarm and disarm your stock alarm with the aftermarket. Plus, you would have double security. There is no reason why anyone should have to arm both separately.
1 Post
right agree with you all. i was wondering tho... if the car happens to lock itself when say....the key is out of the ignition or if the driver's lock is pushed down, or for whatever reason, i would still need the factory key pad with me. im just lookin for a way to easy disable the factory alarm. and the install was a nightmare, i dont want the installer with me car for another 3 days...
hey, my main point to my previous post was that you shouldn't need the factory alarm remote. If the installer installed it correctly, the aftermarket alarm will have total control of BOTH the factory and aftermarket.
btw, my friend and I installed my alarm w/ remote start bypass, and a bunch of other sensors under 8 hrs. You should be careful and go to reputable alarm install places.
Originally Posted by Bambo2888
well, clearly he didnt install it correctly. now on to the solution, please....
1 Post
Like everyone has said, it would probably be best to take it back to him. Being that he installed it, it should be warrantied. These guys that install these alarms usually have to have some certification or training. If you are trying to disable the stock alarm, all you are doing is putting a band aid on the problem. Which in fact, may get worse in the future. A wire could have come lose or come into contact with another, or any other possible secenario. It would be in the best of your interest to solve the root problem. If you oppose to my advice or the members here, that's your choice. As far as disabling the stock alarm, I have not tried and do not know. Goodluck.
1 Post
well actually, ncxvtguy83, maybe you can answer some of my questions.
- the bypass didnt end up working, so remote start is currently decommissioned. can you please tell me which one you used and exactly how you did it?
- when i open the doors, the courtesy dome light does not automatically come on, however, we i switch it to the on position, it comes on. my guess is that that door trigger wire or the relay that controls it is fried because i know for a fact that it is hooked up to the correct wire. what this problem means is that they only way I am currently protecting my car is with a shock sensor because the alarm brain does not recognize any doors as open or closed.
- do you have the trunck pop installed? we have tried everything with every wiring schematic. have any info?
my friend and I have taken over the install/repair process of my security system (hes good with wiring) because of the dealer troubles that i have had. any advise would be great. he should be on this thread to read your response soon. thanks man, i really do apprieciate it.
-as far as your dome light, did you test all 4 doors to make sure all 4 triggers were bad? If you tried all 4 doors and the dome light still doesn't come on. You may have a bigger problem. My first guess would be your multiplex module was fried. If that has gone bad, expect to spend about $100 or more. When did you start to notice the domelight not coming on with the door triggers? before or after the alarm install.. It also makes me think your multiplex unit is bad since your alarm doesn't detect the doors being opened, which controls your door triggers(that's why your alarm doesn't go off when you open the door) and in turn control your domelight.
*the multiplex is located right behind your glove box.
-for the trunk pop, you need to wire up a relay to give a 12v output. On your alarm brain, there should be a trunk pop 200ma pulse wire. You connect that to the relay then your 12v output of relay to the trunk pop wire of the Multiplex unit.
*I would use a multimeter to test everything. Do all these at your own risk, b\c I will not be responsible for your lack of skills.
by the way, if you need a multiplex unit for a 1999 TL. I may have a brand new one. Let me know.
1 Post
thanks dude. i know for a fact something is fried because my friend was testing the voltage on the door triggers up behind the pass. fuse panel and he connected one of the groud with soemthing else with the multitester, then he heard the sound that a shorted wire makes, and bam, the domelight isnt trigger by the doors. Also, i did notice that none of the doors will tigger the light.
other than that, the trunk pop gave us hell, and it still doesnt work. im going to try to get my expert friend on here. look back for the next day or so.
thanks man, i really do appreicate the help.
joflewbyu2
10-08-2015 11:16 AM
