External Transmission Filter.
Old 08-10-2012, 12:21 PM
BuffaloGreek's Avatar
I'm going to do a 3 x 3 change, and change the filter.
I wanted to make sure that this was the correct filter before I order it.
Amazon Amazon
Thank you in advance fellow members!
Old 08-10-2012, 12:31 PM
acutee's Avatar
That is the one.
BuffaloGreek (08-10-2012)
Old 08-10-2012, 01:05 PM
Thanks Acutee!
Old 08-10-2012, 02:30 PM
3.2TLc's Avatar
Hey Acutee, Is this a factory "oem" installed external tranny filter ? Could you possibly give me some details on the exact location of this filter ? I'd like to change mine or add one if necessary to my 2000 TL. Thanks a million !
Old 08-10-2012, 02:48 PM
acutee's Avatar
That is Factory OEM installed Filter, not add-on. Follow the thread below with step by step instructions and pictures. The OEM filter and the aftermarket, to me, is almost identical. I bought both and they are both as good. It is very easy to do; I did it by just removing the battery and tray for easy access and didn't need to remove the air intake.
Just make sure when you removed the filter, put a rag right under where the filter was removed from as fluid will slowly come out from the transmission; fluid is also in the filter so be careful not to spill.
https://acurazine.com/forums/2g-tl-problems-fixes-117/transmission-bypass-spin-filter-replacement-852465/
The following 2 users liked this post by acutee:
01tl4tl (08-13-2012), 3.2TLc (08-10-2012)
Old 08-10-2012, 09:43 PM
3.2TLc's Avatar
Tranny Filter
Thanks to Acutee for the thread link. Wow, ask and I received the best write-up that anybody could ever want to enable the involved task to be done from start to finish. Excellent detailed "DIY" !!!! for something that I was'nt even aware of.
For some reason........I think that Acura was rather elusive with this filter. I'll bet most of the TL's out there are running around with this filter in a bypass mode. Is there anything other than the radio code that will be affected by removing the battery ?
Old 08-13-2012, 11:05 AM
acutee's Avatar
Just radio code, anything else is as usual, like losing radio stations, seat memories.
rcs86
08-02-2016 06:52 PM
knight rider
03-04-2016 08:59 AM
xsilverhawkx
10-05-2015 11:00 AM
hashbrown
09-29-2015 12:13 PM
jmaxima03
09-27-2015 10:22 AM
Quick Reply: External Transmission Filter.
