Exhaust resonator
Old 04-19-2006, 02:38 PM
  #41
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Yep thats the wrong one. (not that its that wrong, i have that one removed also. You need the larger one removed.
Old 04-19-2006, 02:42 PM
  #42
DRINKING HAS A ME PROBLEM
Rpappi's Avatar
if i have both removed how loud is it going to be???
because as is it is just barley louder than before.
Old 04-19-2006, 02:44 PM
  #43
fsttyms1's Avatar
the little one does almost Nothing for sound. Go get the big one removed (and complain that they removed the wrong one maybe they will do it for free
Old 04-19-2006, 02:59 PM
  #44
Rpappi's Avatar
they wont i already tried that. it wasnt all there fault. little bit of mine too. initailly i told them to take off the second/larger one. they they started to question what i was saying. i told them i wanted it to be a little louder so i could actually hear it. and so that is the one that they took off.
Old 04-19-2006, 03:55 PM
  #45
fsttyms1's Avatar
So you go back yet and get it taken off??
Old 04-19-2006, 04:35 PM
  #46
Rpappi's Avatar
going later. will this mess with my emmissions. im thinking not but just thought that i would ask and make sure.
Old 04-19-2006, 05:44 PM
  #47
Rpappi's Avatar
ok well nevermind with the emmisions question i answered it myself. ill try to get it done tommorrow. i cant wait
Old 04-19-2006, 06:08 PM
  #48
fsttyms1's Avatar
Nope it wont. Its purly for sound cancelation
Old 04-19-2006, 06:40 PM
  #49
Rpappi's Avatar
ya i was sitting there thinking about it and i realized i was being stupid. im going to end up taking the second one off also im hoping its not going to be too loud.
Old 04-19-2006, 06:44 PM
  #50
fsttyms1's Avatar
I couldnt tell the difference after i removed it (removed the large one first)
Old 04-19-2006, 06:47 PM
  #51
Rpappi's Avatar
ya there was a very minor difference when i took it off. but the next one is the big step up. we will see.
Old 04-20-2006, 03:53 PM
  #52
Rpappi's Avatar
got it done today. really not a huge difference just alittle louder. but sounds much better i hear that more than my sucking noise from my intake. glad i did it.
Old 04-20-2006, 04:24 PM
  #53
fsttyms1's Avatar
Old 04-20-2006, 04:28 PM
  #54
Rpappi's Avatar
while they were doing it they managed to pull the o2 sensor out of the cat so when i left the check engine light was on. i went back and argued it with them. and made them check it and low and behold i was right. o well they were nice about it. but its done and sounds nice.
Old 04-20-2006, 04:41 PM
  #55
fsttyms1's Avatar
How in the world did they do that? its no where near the resonator????
Old 04-20-2006, 09:05 PM
  #56
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
why were the anywhere close to the O2 sensor. The resonator is close to the rear left wheel.
Old 04-20-2006, 10:02 PM
  #57
joe80055's Avatar
It would actually be helpful if someone inserted or provided a sound clip of what the results would sound like.. then it'd be alot more convincing.. understand what I mean? I mean hey, if i could just remove a silly little piece rather than buying a different exhaust all together, that'd definitely be awesome! haha By the way.. with this mod, how does it comply to regular state inspections?
Old 04-20-2006, 11:53 PM
  #58
Rpappi's Avatar
ill get a sound clip i still running stock exhaust. it will not effect the emissions at all it is simply a sound deadner. nothing more. just like the intake resonator. the sound is not changed much slightly louder not much. on the freeway you can barley hear it. road noise is more but under light acceleration you can tell a decent noise increase. its not obnoxious at all. if you turn on your music just a little bit you cant really hear it at all. i recommend it. no downside IMO ill have a sound clip hear soon.prob try to tommorrow.
Old 04-20-2006, 11:58 PM
  #59
Rpappi's Avatar
there is a flex pipe in front of the cat that allows the exhaust to bend alittle so you can work on it and nothing cracks during driving. and they cut the pipe right before the second res. and the pipe bent at the flex pipe and the only thing stoping it from pulling further down was the o2 sensor/wire and it pulled the wiring harness out. im not good at explaing things so i hope that you understand that. ill try to find a picture and point it out.
Old 04-21-2006, 08:45 AM
  #60
fsttyms1's Avatar
Your not going to get much from the sound clip. Its very subtle in sound change. Wont do a thing vor state inspections. Its purely for sound, and since its not loud it wont make a difference
Wouldnt have thought it would have bent that far to pull on it. Ive had mine apart a few times and its never fallen enough to tug on the wire
Old 04-21-2006, 09:02 AM
  #61
Back in a Type S
ProvidenceLeaf's Avatar
I feel stupid to repeat this, but if I took the resonator off completely would it be annoying? Or should I get one of those smaller tube resonators like a 16" or 18"?
To give you an example of my taste...I like hearing the rumble of a Mustang GT. I know it won't sound anything like when I had my Mustang and I took the cats off. (I had straight pipes to the mufflers) I just wanted to give you an example of my taste to help out with your suggestions. I have Copmtech axle backs. Thanks!
Old 04-21-2006, 12:18 PM
  #62
ultimatetl's Avatar
I did that to my 93 honda Civic. straight pipe to flowmaster from cat without resonator.
I hated that setup because it sounded like a fart can. Then again it was a 4 bangger.
Well, I will just take one of the resonator out on my TL-S and enjoy it then....
Old 04-21-2006, 12:24 PM
  #63
fsttyms1's Avatar
If your running stock exhaust No. its just a real SUBTL sound change. Its not like pulling a muffler off a car!
Old 04-21-2006, 01:51 PM
  #64
Rpappi's Avatar
its able to and it will. he put pressure on it when he was cutting and i made an error when i was telling you how it happened. he cut the hanger holding the res. then cut the res on the back side so it had the weight of the res on the wire. then when he was cutting it he was putting pressure on the wire by pushing down on it while he was cutting. he was not gentle. but its fixed now so no problem.
Old 04-21-2006, 01:57 PM
  #65
Rpappi's Avatar
if you went and bought the car off the lot it would not seem like you did anything to the exhaust. take both resonators off if you just do one you really wont notice anything. if im drive under normal load. accelerating and have the sterio on at all you cant hear it. now if you really get on it. it is still slightly noticeable but really like i said it does not sound aftermarket. if we had a true duel exhaust it would sound more like a 350Z. which i was told that if i took off my res it would sound like. it does not at all. but it sounds better. do it you wont regret it.
Old 04-21-2006, 03:25 PM
  #66
03CoupeV6's Avatar
I've heard 350Z exhaust notes (I'm the one who told you that) and that's what it sounds like to me. Not nearly as loud, but V6 exhaust notes aren't going to vary that much. I wouldn't want it to be as loud as the 350Z. Plus I only had the largest resonator removed, not both.
Old 04-21-2006, 03:43 PM
  #67
fsttyms1's Avatar
it does soud like a 350z, just not as loud
Old 04-21-2006, 11:42 PM
  #68
Rpappi's Avatar
i dont know i have heard a few 350Z roll past me it just sounds different. i think they have a real duel exhaust.
Old 04-22-2006, 05:04 AM
  #69
03CoupeV6's Avatar
I don't think they have real dual exhaust. I think it's a split just like the TL's. Not positive, though.
Old 04-22-2006, 09:25 AM
  #70
fsttyms1's Avatar
Wouldnt matter, thats not all that causes it. motor, head design, pipe length, mufflers, ect..... all go into the sound of the exhaust. While the TL isnt the exact same it does sound similar, just alot more subdued!
Old 04-22-2006, 07:13 PM
  #71
Rpappi's Avatar
i agree with you that it sound like a 350Z in the fact that it sounds like a V-6 but there is a distinct diffence in sound. both sound really nice. but i can tell the difference in the note.
Old 04-23-2006, 11:02 PM
  #72
Rpappi's Avatar
i have some video not very good (really windy) but its not bad for the conditions that i was in. what is a good website to host or can anyone host them for me.
Old 04-23-2006, 11:17 PM
  #73
Rpappi's Avatar
i drove out to see my fiancee this weekend. and for anyone worried about sound and the dronning effect on the freeway. at 60 you can hear it if you are listening for it and radio is off. 70-80 you cant tell even if you are listening for it.
Old 04-25-2006, 12:47 PM
  #74
Rpappi's Avatar
decided that removing the exhaust resonators and getting a CAI were a bad Idea. now everytime that i drive i want to hear both and end up going out of my way just to hear them.
Old 04-25-2006, 01:41 PM
  #75
fsttyms1's Avatar
Dont worry you will get out of that phase. sorta
Old 04-25-2006, 05:50 PM
  #76
Rpappi's Avatar
i hope i dont get out of that phase. i love this phase.
Old 05-14-2006, 10:30 PM
  #77
ultimatetl's Avatar
I finally did it. But they accidentlly removed both resonators.
It sounds pretty cool but at 2300+/- rpm its droning sound is pretty annoying, espically when I cruise at 75~80 mph.
I might ask them to put the llittle one back on.
Does anyone have both removed?
Old 05-15-2006, 08:16 AM
  #78
fsttyms1's Avatar
Are you on stock exhaust? I have both removed and its not bad at all. The little one does very very little to the sound. its the big one that does all the work.
Old 05-15-2006, 01:54 PM
  #79
Rpappi's Avatar
i have no droning noise at all. i can hear it when accelerating but at a constant speed i cant hear it at all. at freeway speeds the wind noise is way louder than the exhaust. turn your climate control on and listen to music softly. you wont hear it. BTW i have both removed.
Old 05-15-2006, 08:57 PM
  #80
ultimatetl's Avatar
hmmm....
I do have stock mufflers. Could it be the new muffler tip?
I have oval shape tips added when the resonators were removed.
they cut the mufflers tips about 3" and welded them on.
I don't think tips cause the noise but do know what else...........
Quick Reply: Exhaust resonator
