Excellent Info on Coolants- MUST READ
This is an excellent article written by the editors at motor.com regarding coolants. All of the info they present in the article is valid:
http://www.motor.com/MAGAZINE/Articles/082004_04.html
Yep.
Motorcraft Premium Gold/Zerex G-05 would be my recomendation as a "universal" coolant. I would however, continuously drain/refill the system with drinkable water (running engine up to normal temps in between each drain/fill) until the discharge is clear. This way, you would have removed nearly all of the old coolant. Generally, it takes three to four drain/fills with clean water. Only use the Prestone Super Flush if the system appears dirty, and if you do, it is especially important that you do at least three to four water flushes after its use to remove as much cleaner as possible.
You can buy the Motorcraft Premium Gold Concentrate for $15/gallon at any Ford Parts counter...
Ill stick with my new "BLUE" honda coolant in mine Good read though
Originally Posted by NSXNEXT
I went over 90K on my original coolant and it looked fine. Replaced with Honda blue.
I would change my coolant every 5 yr or 100K, whichever comes first, but that's just me.
Appearance is deceiving when it comes to coolants. You can drain 10 yr old coolant out of a radiator and it could still look OK. The correct test would be to check it's PH.
Testing for temp does nothing more than checking the correct concentration level...your coolant could be a 50/50 mix that's 20 yrs old and it'd still test OK.
Originally Posted by VeeralS05
I use Water Wetter and Distilled Water
I would recommend draining and refilling the system with drinkable water, running the engine until it is hot, and repeating this for three additional times, before adding the correct amount of Motorcraft Premium Gold or Zerex G-05 concentrate and water.
My
I NEED MONEY!
I would never run water wetter and distilled water in a cooling system. Never. Water Wetter simply does not have sufficient anti-corrosion additives and protection against cavitation. In addition, I'm not sure what effect water wetter has on the boilling point of water, but the solution in your system could easily boil in the event of the slightest radiator cap failure and/or system leak.
My
My
4drviper
09-23-2015 09:00 PM
