Engine still misfiring
Old Jul 29, 2011 | 11:18 AM
SuperDan's Avatar
6th Gear
I replaced all my spark plugs, but it's still misfiring. Any help please? Could it be my coil packs? if so how much does it cost?
Old Jul 29, 2011 | 12:23 PM
fsttyms1's Avatar
Most likely just 1 coilpack. Buy one and and start putting it on 1 cyl at a time till the misfire goes away.
U can get them for like 55 bucks
Old Jul 29, 2011 | 03:06 PM
ou sig's Avatar
Boomer SOONER
rockauto.com has them for $35 - $50 each
Old Jul 29, 2011 | 05:02 PM
mugenspire's Avatar
3 pedals in my 99 TL
this. and make sure to reset the ECU after u find out which coil is bad.
Old Jul 29, 2011 | 05:41 PM
01tl4tl's Avatar
exactly what plugs did you install? NGK Iridium? were they about 8 dollars each?
are you getting multi cyl misfire codes?
thats usually 1 coil bad as said above
did it miss before the plugs?
have you done the egr port/passage system clean yet? that will cause a miss
did I come in on the middle of this story -already in progress? any backstory??
Old Jul 29, 2011 | 05:44 PM
01tl4tl's Avatar
when doing the try new coil on each cylinder (start with ones listed by codes)
reset the ecu after each coil movement
if doing the test method of remove the power lead to coil and ck for rpm drop or no drop, you dont have to reset ecu- just plug wire back in tight and remove next ones till the rpm doesnt change = the dead one
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
