Engine prob.
Engine prob.
Whenever I start my car, the main. required signal flashes for a couple seconds than goes away. Should I be worried, or should I just be safe and take it to my dealer?
- Brian
- Brian
it starts to flash when you turn the car on when you are within 1000 miles or less of a scheduled maintenance... whether it be an oil change of a routing service.
If you are overdue for a service, the light will stay on to remind you instead of just flashing when you start the car.
The light you need to watch for is the check engine. The maintenance req. light is just there to serve as a reminder that cars don't run forever without proper maintenance.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
