Engine Noise (video)
Old Mar 28, 2014 | 07:13 PM
Neejay's Avatar
Hopefully you can hear it, just listen closely. It's also very audible from outside the car. It's only around 1k RPM and goes away...but it's EVERYTIME I rev to start driving.
Hopefully not a bearing(s)?
Old Mar 28, 2014 | 07:41 PM
Skirmich's Avatar
Sounds like you may want to check those valve clearances... if it goes away with a hot engine its definitely the valves...
Old Mar 28, 2014 | 10:18 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Exhaust Heat shields check them all, Manifolds and catalyst area.
Could be loose or broken, if its not that the noise is elsewhere.
Old Apr 1, 2014 | 06:49 PM
johnep's Avatar
Take the drive belt off and see it the noise goes away. It almost sounds like the a/c clutch plate broken or rattling or something right by the belt.
Old Apr 6, 2014 | 10:11 PM
Neejay's Avatar
Nope, the noise is there regardless of cold/hot.
I don't have any shields.
Ok, I'll try this.
Thanks all for the suggestions.
Dec 13, 2015 02:21 PM
real_mckoy
4G TL Problems & Fixes
Sep 25, 2015 10:49 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
jliu6789
Sep 8, 2015 08:02 PM
