engine mount question
look in the parts books for comparison of numbers
do you have a set from another year laying around?
There are 3 different motor mounts that go on that car. Many places call two of them motor mounts and 1 a transmission mount. If you call your local dealer they will give you the exact part numbers to all 3 that are installed in your car. I have the RR mount for sale on the Black Market. There is also one on the firewall side (passenger side) and one in the front under the motor. Hope that helped.
front of car - left side of engine - acura calls `front mount`
pass side (actual front of engine) fails sometime after front goes undetected in its failure and adds stress to the side mount
the rear motor mount is the firewall side (right side of engine)
there are also 2 more trans mounts
your dealer or one of our dealer vendors for info and prices
mention azine to our sponsors for special price
see vendor list at top right of pages- next to logout
the front and rear mounts are the ones that MAY be vac assisted
replace with same or plug line securely so no mystery vac leak
a bad mount with booster will cause a mystery vac leak no tech can find!
Lead Footed
In my case, I have an aftermarket front mount and have plugged the vac line.
Ruf
is that passenger side?
they make quality products- I would use one on my own car
thats a `normal` type mount- just a rubber bushing attached to metal plate
beck would be fine
iirc the dealer gets about 50 for that part (price info a few years old)
beck would be fine
the front and rear- which are the sides of the engine in reality- are the expensive trick ones with vacuum boosting
sockr1
10-01-2015 01:31 AM
