engine mount question
Old Oct 17, 2010 | 06:49 PM
tantrumichy's Avatar
i have a 2003 tl type s. Are all the engine mounts for a 99-03 tl the same?
Old Oct 17, 2010 | 07:28 PM
FirePR2002's Avatar
bringin lead
i don't think so. some years have vac lines and others do not.
Old Oct 17, 2010 | 08:48 PM
01tl4tl's Avatar
look in the parts books for comparison of numbers
do you have a set from another year laying around?
Old Oct 18, 2010 | 08:00 AM
GGENOVESE's Avatar
There are 3 different motor mounts that go on that car. Many places call two of them motor mounts and 1 a transmission mount. If you call your local dealer they will give you the exact part numbers to all 3 that are installed in your car. I have the RR mount for sale on the Black Market. There is also one on the firewall side (passenger side) and one in the front under the motor. Hope that helped.
Old Oct 18, 2010 | 11:18 AM
01tl4tl's Avatar
front of car - left side of engine - acura calls `front mount`
pass side (actual front of engine) fails sometime after front goes undetected in its failure and adds stress to the side mount
the rear motor mount is the firewall side (right side of engine)
there are also 2 more trans mounts
your dealer or one of our dealer vendors for info and prices
mention azine to our sponsors for special price
see vendor list at top right of pages- next to logout
Old Oct 18, 2010 | 11:20 AM
01tl4tl's Avatar
the front and rear mounts are the ones that MAY be vac assisted
replace with same or plug line securely so no mystery vac leak
a bad mount with booster will cause a mystery vac leak no tech can find!
Old Oct 18, 2010 | 11:32 PM
RUF87's Avatar
Lead Footed
Correct, in the case of my 02 both front and rear mount use vac to firm up the mount under acceleration. Meaning it will make the mount stiffer. If one of the mounts fails - busts - it is possible to have a vac leak of sorts. Depending on the degree of failure that is.
In my case, I have an aftermarket front mount and have plugged the vac line.
Ruf
Old Dec 13, 2010 | 08:46 PM
03c0upe's Avatar
1999 tl
anyone using a BECK/ARNLEY right engine mount? any good>?
Old Dec 13, 2010 | 09:13 PM
01tl4tl's Avatar
is that passenger side?
they make quality products- I would use one on my own car
Old Dec 13, 2010 | 11:00 PM
03c0upe's Avatar
1999 tl
yeah passenger side
Old Dec 14, 2010 | 01:22 AM
01tl4tl's Avatar
thats a `normal` type mount- just a rubber bushing attached to metal plate
beck would be fine
iirc the dealer gets about 50 for that part (price info a few years old)
Old Dec 14, 2010 | 01:23 AM
01tl4tl's Avatar
the front and rear- which are the sides of the engine in reality- are the expensive trick ones with vacuum boosting
Old Dec 15, 2010 | 06:02 PM
03c0upe's Avatar
1999 tl
ok thanks, im gonna go ahead and order that brand
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
datadr
Sep 2, 2015 06:46 PM
