Engine mount.....after research
Old Oct 10, 2005 | 04:24 PM
MY2002TLS's Avatar
Exclamation Engine mount.....after research
Ok I posted my issue a while ago, after some more research I am now thinking it is the front motor mount, instead of the axles.
Please refer to my last post.....https://acurazine.com/forums/showthr...117690.....and see what you all think.
I just went out to my car and put one foot on the break put it into drive and excellerated a bit. The front of the motor lifted anout 1.5 inches, then I did the same in reverse and it didnt lift as much.
I tried both reverse and forward due to the opposite torque twist.
Are there any other tests I can do to narrow this down?
thanks...
Old Oct 10, 2005 | 05:15 PM
MY2002TLS's Avatar
Nothing yet????
Old Oct 10, 2005 | 06:10 PM
MY2002TLS's Avatar
Please help anyone.....
Old Oct 10, 2005 | 09:12 PM
fsttyms1's Avatar
You kinda did it. Im dont rememer off the top of my head what teh other sign is on teh front one being bad. It kinda sounds like the front one is bad if it moved that much
Old Oct 11, 2005 | 12:50 AM
MY2002TLS's Avatar
Ya thats what I thought too. Are there any after market "heavy Duty" ones anywhere?
Thanks for getting back to me....looks like nobody else cared!!
Old Oct 11, 2005 | 01:13 AM
LiquidThinker's Avatar
Playing Naked!
What type of mounts does the TL have? I know we have had luck with maximas pressing out the worn mount and filling with different compounds to create a more firm mount.
Old Oct 11, 2005 | 10:09 AM
fsttyms1's Avatar
None aftermarket that are "Heavy Duty" that i know of. There may be ones you can buy in a parts store but i dont know if they are better
Yea we dont have those type. I helped my buddy do that on his. We have 2 that are vacum assisted motor mounts, and those are what tends to wear out.(in particular the front one)
Old Oct 11, 2005 | 11:59 AM
SiCrew's Avatar
if you're under warranty, acura might replace it...they replaced an engine mount for me when I got my new tranny...good luck
Old Oct 11, 2005 | 04:21 PM
NSXNEXT's Avatar
I believe TypeR on the CL board did that to his motor mounts (not sure which ones f/r)
Old Oct 11, 2005 | 06:01 PM
fsttyms1's Avatar
can you fill the vacum style ones? i know the side oneits probably possible. Didnt know or think you could do it to the front and rear ones
Old Oct 12, 2005 | 03:35 PM
Playing Naked!
I will have to get a hold of the TL this weekend and take a look at the mounts. I know we had a lot of success with the maxes and it was cheap.
Old Oct 12, 2005 | 09:40 PM
prjctTL's Avatar
test
you will feel a thump from the front of the car right when you hit the gas, like as if something was loose. hope that helps
Old Oct 13, 2005 | 12:21 AM
MY2002TLS's Avatar
Cool thanks all.
I am pretty sure it is the front mount. Any do it yourselfers out there? Any advice?
Thanks...
Old Oct 13, 2005 | 11:37 AM
Front is easy, took me 30min.
place a car jack under your engine oil pan jack the engine up a little about 1 inch.
Disconnect the mount vacume line.
Remove 4 bolt at the bottom and one on the top of the mount.
Then remove the mount bracket from the engine block (3 bolt).
Remove mount
install new mount
reinstall the bottom 4 bolt
install the mount bracket (28lb/ft torques) (you might need to play around with the jack to reposition the engine to the mount)
reinstall mount top bolt (40 lb/ft torques).
reinstall vacume line
remove the jack.
drive the car around the block
then loosen and tighten the top bolt again
Good luck
Old Oct 14, 2005 | 12:35 AM
acutee's Avatar
Remove mount
install new mount
remove the jack.
Good luck
Did you have to remove the side engine mount before raising the engine up an inch?
Old Oct 14, 2005 | 10:19 AM
No you don't have to remove the side engine mount. You are just removing the support pressure from the front engine mount so you can remove the mount. The side engine mount is flexible enought for you to move the engine around a little.
Old Oct 14, 2005 | 12:21 PM
MY2002TLS's Avatar
Remove mount
install new mount
remove the jack.
Good luck
Thats easy...thanks for the info!!
Old Oct 15, 2005 | 06:37 PM
acutee's Avatar
Thank you pdprich. That is a great info to know.
Old Oct 16, 2005 | 12:47 AM
2007AcuraRL's Avatar
What made you narrow it down to a motor mount when in your earlier thread you'd ruled that out? And how did you determine it might be the front mount but not the side one? I ask because I have a vibration as well and I dont think its wheel balancing. I drive a considerable amount of miles a year (25k) and starting about 20k miles ago, i would get a vibration at speeds above 78MPH, and its gotten progressively worse so now I get vibration at anything over 70MPH. The thing is, there is no vibration when the car is idling. additionally, when I am driving at 75MPH and getting the vibration, I will put the car in neutral to take load off the engine yet the vibration is still there.
Ok I posted my issue a while ago, after some more research I am now thinking it is the front motor mount, instead of the axles....
Old Oct 18, 2005 | 09:35 PM
MY2002TLS's Avatar
I just kinda came to that conclusion after reading a lot of threads!!!!
Feb 25, 2020 09:57 AM
atsx1313
Sep 22, 2015 09:04 PM
Sep 17, 2015 09:01 PM
Sep 17, 2015 10:16 AM
