Engine mount 02 Type S
Old Jun 15, 2011 | 01:17 PM
inline-06's Avatar
5th Gear
How can you tell that your front engine mount is bad? I have a 02 TL.
Old Jun 15, 2011 | 05:17 PM
01tl4tl's Avatar
ck other threads with pics of following things if they dont make sense:
compressed look to upper rubber part
odd drops of oil on garage floor
actual oil traces on bottem of mount (its oil filled)
mystery vacuum leak
Engine moves wildly when gas pressed -in gear- park brake on - brakes on by TRUSTED helper (not angry spouse~)
there is more than 1 vid on azine of the movement
pretty much more than 1/4 inch is too much--so 2-3 inches of engine motions is definetly bad mount
When the front goes (usually 60-80kmiles) and isnt detected for months, the passenger side mount takes extra load and fails too, luckily its a normal rubber mount
Old Jun 15, 2011 | 06:39 PM
closetprisoner's Avatar
2000 Acura TL
It'll look something like this...
Old Jun 15, 2011 | 07:56 PM
fsttyms1's Avatar
not always. That's a recent failure. Some have died far before and all the fluid would have dried
Old Jun 15, 2011 | 07:57 PM
fsttyms1's Avatar
The best way is with a vacuum gauge or look for excessive engine movement when in gear
Old Jun 16, 2011 | 01:56 PM
2000 Acura TL
Was actuall dry when remove, i kicked accidentally then it spill.. lol
fsttyms1 - like your thread with A4 headlight.
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
