Engine motor mount - 02 TL-S
Old Oct 5, 2016 | 06:58 PM
TL260power's Avatar
I need to change both front motor mounts as they are broken. I need help to select the correct ones.
I went here: ENGINE MOUNT for 2002 Acura TL SEDAN
Is this the front right? MTG RUB ASSY ENG FR for 2002 Acura TL SEDAN|50800-S0K-A82
What about the front left? (driver side)
I also need to change the passenger side foglight unit. To determine the Left or right unit. Is it determined by you standing in front of the car and see it as left and right. Or siting inside the car and look at it that way as Left and right?
http://www.oemautopartz.com/acura/au.../foglight-scat
Old Oct 6, 2016 | 06:22 AM
you're doing great TL260power, but why dont you believe the description???????
it clearly says mount for 2002 TL. so, yes indeedy, it is the right mount.........ESPECIALLY from an acura dealer website...
and the DRIVERS side is ALWAYS the LEFT side. remember that! Driver side is LEFT side.
Old Oct 6, 2016 | 11:32 AM
SuperGreg's Avatar
There are five mounts total, front and rear pneumatically controlled, right (passenger) side rubber mount, and two rubber transmission mounts on the left (driver's) side underneath the tranny. You can inspect these behind the left front tire.
I'm not sure exactly which one you're referring to? The link you posted to 50800-S0K-A82 is the front mount.
Old Oct 6, 2016 | 01:55 PM
TL260power's Avatar
The mechanic said the front two mounts
Old Oct 6, 2016 | 02:16 PM
MBP 03's Avatar
There is only one front mount. When you open the hood, it's visible between the radiator fan assembly and the exhaust manifold heat shield. All other mounts are as described by SuperGreg.
Old Oct 12, 2016 | 01:44 PM
ExcelerateRep's Avatar
Former Sponsor
This might help your situation out.
XLR8-MM-9903TL - XLR8 Engine Mounts - Excelerate Performance - European, Exotic and Japanese Performance Specialists!!
gavriil
Jan 6, 2025 01:04 PM
Flipster23
Norcal
262
May 4, 2023 02:47 PM
EE4Life
Dec 20, 2022 05:16 PM
EE4Life
Mar 12, 2020 07:29 PM
EE4Life
May 14, 2016 07:14 AM
