engine drop
Old Feb 9, 2009 | 08:39 AM
jwtinid's Avatar
Angry engine drop
Cam belt apparantly skipped a tooth in my 2000 TL and grenaded the motor. I can't even turn the crank via the crank bolt 10 degrees either left or right via a socket wrench without hitting something hard. Anyway, I am going to pull it and install a lower milage used motor. The question is-can I pull it out the top? Chilton's gives a procedure for lowering it out through the chassis.
Since I don't have a lift, but do have access to a engine hoist, I would much prefer to come out the top rather than having to pick up the front end at least 30" or more. Any suggestions welcome.
Old Feb 9, 2009 | 09:05 AM
AMGala's Avatar
Lamborghini Aventador FTW
It can be done, as this is what our Mega Mod fsttyms1 did when he converted to a manual trans:
Old Feb 9, 2009 | 04:08 PM
jwtinid's Avatar
engine drop
So you had to pull the tranny prior to lifting the motor? The "expert" at the recycler's said that it could be done also, but a lot more work. I just have to figure out how to lift the front end 24" with a floor jack, without dropping something. The guy said to lower the engine to the ground and then lift the car.
Old Feb 9, 2009 | 04:20 PM
bowlgers's Avatar
268hp 301tq @7.8psi
if u dont know how to do this it can be hard but if u do its not hard at all about 2 hours to get it out and the tranny doesnt have to come out i do this all the time just make sure u get the tourqe converter bolt out before u pull it out i see too many people forget and twek the flywheel good luck
Old Feb 9, 2009 | 06:38 PM
fsttyms1's Avatar
Pull the trans and motor out at the same time. Believe me you will thank yourself. It will be far easier to unhook the trans and rehook it together. It is far easier to bring it out the top.
Also you can unhook the wire harness from teh ecu and pull it thru the firewall and re wire every thing outside the engine compartment far easier.
uzzmaan
Aug 4, 2025 08:29 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
CLsuperhero
Sep 23, 2015 12:53 PM
Sep 17, 2015 09:01 PM
Skirmich
Sep 15, 2015 06:41 PM
