Engine Code Help
Old Mar 1, 2005 | 10:05 AM
hoclocka49's Avatar
3rd Gear
Engine Code Help
Hello Everyone,
99 TL-P
After searching around on the Forum I realize what my engine codes mean, but I am still having trouble finding out how to fix these issues...
P1676 - FPTDR Signal Line Malfunction. I couldn't find any information anywhere to what this could be?
P1492 - Malfunction in EGR System. I found some information regarding cleaning the EGR ports on the Intake Manafold, and also information on a possible voluntary replacement of the EGR Valve from Acura. Unfortunately, my car just passed the 80k mark the other day.
I cleared the codes yesterday and they have not come back yet. Although, I would rather play this one safe. If you guys have any information that you think may help please post!
Thanks in advance,
hoclocka49
Old Mar 1, 2005 | 05:10 PM
fsttyms1's Avatar
not sue what the other code is for but if you are having a egr related code, you probably have a intake port cloging problem. it is very easy to fix your self if you arent afraid to take off the upper intake manifold (sounds harder than it is. takes about 1 hr to take off and clean and reinstall)
Old Mar 1, 2005 | 08:07 PM
livinglegend's Avatar
ULOOZ
The code p1676 , FPTDR line signal failure. can sometimes be caused by water getting into the connector at the ABS/TCS unit next to your washer fluid bottle. If you spray down the engine compartment as most of do.... that connector gets wet. I have found that by opening the lock on the orange connector and removing the connector from the ABS/TCS , then drying it out, then re-installing it AND securing the lock bar down again, will resolve that code. Take your time!!!!! Do it right, so as NOT to damage the connector lock bar.
Yikes
May 3, 2021 04:29 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
